I need to either make or modify the e brake cross rods that run from the lever/balancer mounted on the rear axle housing to the lever at the backing plate. The reason is that I had to modify the location of the lever/balancer due to using a Austin Healey 3000 rear end on a Daimler SP250. My questions are: can I cut and re-weld my AH cross rods? Or can I just buy some rod material (stainless?) and make completely new rods the correct length? I believe the original rods are tempered or heat treated in some way and I don't know if welding will compromise or change the integrity or if raw SS rod is strong enough. Thank, Josh
