Bob_Spidell
All this voltage talk has got me to thinking: I installed an AGM battery in the BJ8. These register a somewhat higher voltage--around 13.2V according to the cheapie digital VM plugged into the wiring--than wet cell batteries, which should show about 12.6V fully charged. I also installed a new regulator and these two seem to play well together, at least so far, but the VM shows 15V+ max output. A wet cell should charge at something over 13.5V; wonder if the higher charging voltage I'm seeing could cause problems down the road? And to keep things somewhat OT, the 'battery indicator' light operates as expected--i.e. it goes out at anything over 600RPM or so--but I guess since it shows the difference in potential and the battery/charging voltage delta is about the same that seems to make sense?
