TR4/4A Battery recommendation
JimTR4
Hi - can anyone recommend a good but moderately priced battery for my TR4?
Based in US,
Many thanks,
Lou Metelko
All of the TR2s thru the 4As came from the factory with Group 72 batteries, Only the group 72 batteries properly fills the designated space for the battery. The price of any battery in the last half dozen years will take your breath away!
Hate to break the news but good and moderately priced anything are on opposite ends of the equation!
Lou Metelko
Auburn, Indiana
TFB
I use a Bosch 24f about $110 from PepBoys.825cca @ 32degrees.
A few days later my friend bought a similar Motocraft at the ford dealer for about the same price.
Tom
TR3driver
Great Pumpkin - R.I.P
Do you have a Costco in your area? After experiencing their return policy first-hand, I won't buy anywhere else. They don't advertise the details, but I got a full refund of the current new price, on a battery that was 4 years old. Walked out with a new one and it only cost me $5 (the core charge had gone up). The contrast to O'Reillys was extreme. (I had to yell at the manager to even get them to admit that a 72 month battery was still under warranty when it was 3 years old. And the replacement, that cost me as much as the 72 month battery even with their "adjustment", was only warranted for 24 months.)
Sorry, I don't recall the details; but I'm using a smaller battery that was less expensive. With the alternator, it works great for me.
mrv8q
+1 for Costco batteries, exemplary service here.
Geo Hahn
Costco & WalMart are my go-to sources for batteries. I am using Group 27 which mostly fill the available space - was about 100 bucks at WalMart.
I use single fill caps in place of the multi-port it comes with and some faux labels to give it a less modern look:
TR3driver
Lou, what's your reference for that information? I'm curious because, for example, the TR2-3 workshop manual lists Lucas Models GTW7A/2, GTW9A/2, GT9A/2 and
GTZ9A/2. The GTW7A appears to be a much smaller battery than the others. Some poking about on the Internet produced the following meager info
GTW7A 38 ah (10 hr rate) 10-3/4 x 6-7/8 x 9-1/4
GTW9A 51 ah 12.5 x 6.75 x 8
According to the BCI group size chart I have (which oddly enough doesn't match the one Geo linked to)
https://www.batteryweb.com/bci.cfm
a GTW7A is closer to group 24 (10.3L 6.8W 8.9H)
and GTW9A is closer to group 27 (12.1L 6.8W 8.9H)
Note that I'm not saying you are wrong, the Internet is notoriously unreliable and I certainly wouldn't want to bet on those numbers. Still, I'm curious because the battery pocket on my TR3 at roughly 14" by 8" appears to be considerably larger than needed for a group 72 (which https://coastalbattery.com/boatbatt.php?id=14 gives as 9.06 x 7.06 x 8.25 )
Tr4aJim
I recently needed a battery for my TR4a. I went to Costco to get an Interstate battery. They had one listed as “Fitment 35, Group 27”. Unfortunately they didn’t have any in stock. The tech looked at several other stores in NJ, but none of them had it either. He said the closest store with one was in Pennsylvania, in fact almost every store in Pennsylvania had them! Weird. He also said the battery could not be shipped or special ordered. So I wound up ordering a Diehard battery and picked it up at Sears.
Jim
DornTRoriginal TR2/3/3A TR3 Battery Recommendation Triumph 9
B Battery recommendation besides Optima Austin Healey 17
J Battery Recommendation Austin Healey 1
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
