TR2/3/3A TR3 Battery Recommendation
DornTRoriginal
Greetings!
I have been wondering about what battery to buy for my 1959 TR3 and curious if there's any recommendations from LBC experts. I think the question is very subjective as far brands and all of that so I am more interested in what size and type I should consider. I have converted my TR to a negative ground and I am will use halogen lamps, LED lights where ever I can, and afford, plus install a modern radio and sound system eventually. I think the look of the battery is somewhat important but not real critical, I am not a super fan of the new modern design I have seen since they have such a strong "modern" look to them (no offense ment if you have one in your LBC :congratulatory:smile:. Performance and longevity are the most important factors I am guessing, holding a charge for long periods of non operation etc. The next follow-up question is where to purchase is also something I'd like to know if there's a better option. Thanks!
sail
Basic Walmart group 24 here that I took the stickers off. It would look better without the handle but I use it.
TomMull
A group 27 will fit the box and provide enough cranking amps. A 27 F is the same but with the terminals reversed but I don't think that matters much with the TR3. The original battery, from my unreliable memory, had the posts toward the firewall.
Don't count on a big battery to handle halogen lights and other electrical loads, that's the job of the generator.
Tom
sp53
I go to Sears they have a wide verity and I buy a big heavy one; it is all about the lead in those old styles. Plus Their guarantee is great.
mrv8q
I'm happy with my Costco (Interstate) battery and Battery Tender â„¢
trickle charger... 1st battery lasted 8 years.
charleyf
[QUOTE
Don't count on a big battery lights handle to halogen lights and other electrical loads, that's the job of the generator.
Tom[/QUOTE
A generator has a limited output . If you want to run and the key word here is "run" high powered equipment you should consider an alternator. I use a group 24 hold up very well over long periods of non use. I use Sears batteries. I buy the better models. I subscribe that in most cases you get what you pay for. If you buy the cheap model over the more expensive one you are likely getting a "cheaper" product as well.
Charley
TR3driver
Great Pumpkin - R.I.P
The great thing about Costco is their guarantee. They don't prorate like almost everyone else does (including Sears). I returned a battery to Costco earlier this year that had only lasted 4 years (in a non-LBC that had other problems) and they gave me 100% credit towards a new battery. All it cost me was $5 because the core charge went up during the 4 years.
By contrast, the last time I took a battery back to Sears because it didn't last through the warranty period, the replacement actually cost more than the original battery did! I bought the original battery on sale. They pro-rated from the sale price, but would only apply that to the list price for the new battery. So I paid some $60 originally for a 72 month year battery that only lasted 4 years, and they gave me $20 off on a new battery for $85. So I paid $65 for the warranty replacement on a $60 battery! Last battery I ever bought from them.
O'Reillys was even worse, they currently offer only a 2 year warranty on batteries and tried to refuse to honor the 72 month warranty on the last battery I bought from them. I had to get the manager and point out that the warranty terms were printed right on the battery before they would give me any adjustment at all.
mrv8q
Yep, Sears played games with me, too, and I haven't been back in over 20 years. Had a Saab that was very hard on batteries, needing replacement every 2 - 2.5 years, and received good service from Costco every time; no questions asked.
Last time I replaced the daily driver battery, Costco had switched from Johnson Control to Interstate batteries...
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
PatGalvin TR2/3/3A TR3 Battery Size Triumph 13
M TR2/3/3A TR3 Battery cable Triumph 9
mgedit TR2/3/3A AGM Battery for TR3 Triumph 12
P TR2/3/3A TR3 Battery Triumph 5
S TR2/3/3A battery rubber tr3 Triumph 1
NutmegCT TR2/3/3A TR3 battery ground cable Triumph 8
NutmegCT TR2/3/3A TR3 battery pad? Triumph 8
T TR2/3/3A Another TR3 battery box replaced Triumph 5
ekamm TR2/3/3A tr3 battery disconnect Triumph 10
af3683 TR2/3/3A TR3 "J" Bolts for Battery Hold Down Triumph 7
H TR2/3/3A TR3 Battery Box Replacement Triumph 10
M TR2/3/3A TR3 Battery Box Installed Triumph 23
M TR2/3/3A TR3 Battery Box Replacement. Who has the best box? Triumph 13
T TR2/3/3A TR3 - positive earth cable from battery is hot Triumph 2
G TR2/3/3A TR3 Battery Box Triumph 6
S TR2/3/3A tr3 battery corrosion Triumph 23
S TR2/3/3A tr3 battery with positive ground Triumph 8
