TR2/3/3A AGM Battery for TR3
mgedit
Considering an AGM battery for my 56TR3 with generator. I realize this may not be the least expensive option but I like the idea of less chance of leakage. Has anyone done this? Wondering if the generator can supply sufficient current with stock regulator setup to maintain proper charge to one of these batteries. Appreciate thoughts and especially real life experiences. Cheers, Mike
3798j
Bronze
Have had AGM's (Optima Red Tops) in both the TR4A and the GT6 for many years. No problems or issues whatsoever. Both cars still have their original charging systems.
mgedit
mgedit
Thanks Jay, are both cars using generators and if so what is there max output? Cheers, Mike
3798j
Bronze
Both still use their original installed generators (pretty sure the GT6's has never even been re-brushed).
Now, while Optima Red Tops are AGM's, they're still lead acid batteries. I'm starting to think you might be actually asking about AGM lithium batteries. Think possibly they're charging needs might be different.
3798j
Bronze
Below is some possibly helpful information. It's from another forum I visit. It's taken from a discussion on AGM's:
"After much research into the AGM advantages and the primary battery manufacturers, like DEKA, Johnson Controls, Exide, etc. here are some salient points":
1. AGMs have a (lower impedance) higher power delivery rate which makes them ideal for the new start stop engines.
2. Since they are sealed they effectively recycle the hydrogen gases and recombine with oxygen to replenish the electrolyte (they don't lose water as vapor). Only when overcharged do they release gases via a high pressure valve for safety, but this does result in the battery's ultimate demise because the electrolyte balance is unrecoverably "off"
3. AGMs have a lower static discharge rate, so they are preferred for garage queens. They can be sustained, conveniently, with the same battery tenders as Flooded Lead Acid batteries, but check with the manufacturer. I know that the Griot's maintainer, Battery Tender and BMW branded tenders work A-OK, as they never exceed 14.7 volts peak charge. AGMs don't like 14.8 volts or above
4. AGMs don't mind vibration and are leak proof. A nice consideration for our trunk mounted Bimmer batteries... Motorcycle guys love them.
5. More CCA in equivalent sizes compared to LA, but not by a huge margin.
6. Since DEKA makes the AGM Super Start O'Reilly and NAPA AGM Exact Fits, they are a bargain against the OEM (BMW) AGMs. All appear to be made by DEKA....
mgedit
mgedit
Thanks all. My concern is that the 19 or so amp output from my TR3 generator might not be enough to maintain the battery. I thought I had read something about that concern with regard to AGM batteries somewhere, but of course cannot find that discussion now. Cheers, Mike
Lou Metelko
Installed an Optima red top in my TR2 (TS981) when car was finished in 2003. Original generator, original starter, points ignition. Battery Tender maintains through the winter hibernation. I chose the Optima due to my paranoia with acid leakage. When battery did not have enough oomph to start car in spring of 2012, it was replaced with another Optima. The 2 is driven, on average, about 3000 miles per season. I highly recommend the Optima - you will not be disappointed.
Lou Metelko
Auburn, Indiana
Geo Hahn
OTOH -- I never had a traditional lead-acid battery leak. They will vent some nasty gases if they are overcharged but sounds like the AGM do that to.
The advantages of the old style battery seem to be that they are cheap, are easily charged if need be and look more period correct (though I realize there are some AGMs made to look period).
The disadvantages are perhaps that the electrolyte level should be checked and maintained and they must be kept upright & secure.
I think plenty of CCAs are available in both styles.
martx-5
I install AGMs in all cars that I decide to keep more then a few years. The original AGM Battery in my Miata lasted 14 years. The one in my TR3 doesn't have a tender on it, as I just charge it up every other month with a small battery charger and it performs fine.
Here are the charging recommendations for an Optima Red Top...pretty liberal.
[h=2]OPTIMA[SUP]®[/SUP] REDTOP[SUP]®[/SUP] Charging Information[/h] The following charging methods are recommended to ensure a long battery life. Always use a voltage-regulated charger, with voltage limits set as described below.
REDTOP[SUP]®[/SUP] Type: 34 & 34R - 34/78 - 78 - 25 & 35 - 75/25
These batteries are designed for engine starting applications. They are NOT recommended or warranted for use in deep-cycle applications.
[h=3]Recommended charging information:[/h] Alternator:
  • 13.3 to 15.0 volts, no amperage limit.
Battery Charger:
  • 13.8 to 15.0 volts, 10 amps maximum, approximately for 6-12 hours.
Rapid Recharge:
  • Maximum voltage 15.6 volts (regulated), no current limit as long as battery temperature remains below 125°F (51.7°C). Charge until current drops below 1 amp.
Float Charge:
  • 13.2 to 13.8 volts, 1 amp maximum current, time indefinite (at lower voltage).
They are expensive, but are rugged and will outlast a lead acid battery three to four times over.
MGBGM1977 MGB AGM M/C battery MG 15
Scott_Hower AGM [Optima-type] battery in chrome bumper B MG 27
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
