Battery recommendation besides Optima
BrandonBJ8
I've had 2 Optima (Red Tops) go out on me in the past few years so I'm looking to try another brand. I don't think I want to spend $200+ on a yellow top either as I can't justify it for the Optima brand given their red top performance. What other brands/models of batteries do you guys have? It doesn't have to be a high end either, so if you've had great luck with Die Hard, I'd be interested to hear.
Thanks!
I got Napa's brand with high cold start capabilities. Less than 90 dollars. Good warranty. Great starting. They told me it was made by the same people who make Interstate.
B
BrandonBJ8
Tahoe - Do you know what model battery you have?
Is it this one? - https://napaautoparts.com/Catalog/CatalogItemDetail.aspx?A=NBE9834_0300667347&An=599001+101967+50359+2359002+25011&Ar=AND(P_RecType%3aA)
Thanks!
Johnny
Hello Brandon, I don't care to get into what is your favorite brand of battery, but I will add this:
If you don't purchase the correct size (group #) battery your original generator may not be able to keep it charged. If you've installed an alternator it probably doesn't matter. I've found a group 22 battery is sufficent for my mostly original car. Consult your shop manual and owners manual for stats on the size of battery you require.
Michael Oritt
Brandon--
You don't give any specifics as to what was wrong with the Optimas but If I had two batteries go bad in as many years I would want to know why before I bought another one, regardless of brand. You may have some problem in your charging system or some parasitic drain that will kill the next one as well.
FWIW I have used Optima red tops on my Courier and in my wife's 3000 for several years with no trouble.
B
BrandonBJ8
I suspect my generator is going out. I had it rebuilt about 6 years ago and I think it's calling it quits again. I think I'm going to convert to an alternator now to avoid any future issues.
You're probably right about the car causing the batteries to have issues.
Thanks!
Big Healey batteries usually cross-reference to a Group 24. Costcos around here quit stocking Group 24s a while back. In a pinch, I bought a 'generic' Group 24 at a local parts house (around $80); it was an 84-month battery and dang if it didn't last almost 7 years (might have gone longer but it was borderline on a load test and I was taking a long trip). My only complaint was that it was maintenance-free; I prefer being able to check the electrolyte level. I just bought another of the same 'brand;' and this one isn't maintenance-free. I think most batteries are made by Johnson Controls; the price/quality is a function of the plate size and spacing, and the strength of the case.
One thing that kills batteries is non-use. If you can't drive the car regularly get a trickle/float charger. BatteryMinder brand is highly thought of in the aviation community (NFI), and can even bring a mildly sulfated battery back to life.
glemon
I don't know if you can get them in the right size but I am going to recommend a Nissan battery, my 99 Maxima has been going over 12 years on the factory battery. Thought about replacing it as preventative maintanance, but decided to see how long it will last.
According to this article most conventional batteries actually come from only three manufacturers.
https://autos.msn.com/advice/CRArt.aspx?contentid=4023696
Rob Glasgow
Interstate - The last one I had in my BT7 lasted 8 years. I have an I-24F. My car is neg. ground which means the terminals are located to the outside edge of the trunk, not toward the inside like the original setup. I like that set up since the terminals are "hidden" under the shroud and not as exposed to the car cover I keep in the boot. It may make jumping the car a little more difficult, but I haven't had to do that in many years.
bob hughes
:crazy:
Woops
When my battery died I just visited my local scrappy and asked for the biggest battery off a diesel car that they had and that would fit in the compartment of course.
Got a nice one for £10 and I do not have any trouble with it.
:cheers:
Bob
Ed_K
I originally had a red top optima but I learned the hard way
that red tops are not supposed to be discharged all the way.
The 1st time mine was discharged all the way, I simply charged it back up and all was OK. The 2nd time I accidentally
discharged the battery all the way, it was ruined and would not take a charge.
The yellow top is designed to be able to be discharged all the way without any bad effects.
The guarantee was good so the Yellow top was mostly paid for by giving them back the bad red top.
No troubles from the yellow top but I don't think I have accidentally discharged the yellow top since I got it.
BoyRacer
As soon as you stop using your battery it begins to sulfate. Your everyday driver never has this problem so that battery will last for years. If you are not driving your Healey, make sure you zap your battery at least once every a week or two with a charger to stop the sulfating process.
jsfbond
The automotive battery is designed to cycle down only 15% anything below that on a regular basis, and its the beginning of the end. A battery maintainer is the thing, even if you are just parking it for the five day work week, and driving it on weekends. It give the battery a "stir" every so often an this will make it last for ever. We have a low $$ end battery attached to our starter tester (put on in 1998, with a maintainer) it just sits on the bench until we need to test a starter,still going strong.Schumacher (#PSC-15A-OB) makes the best for any 12 volt vehicle storage.
PS. In the late nineties the battery in a average new GM car when driven on a cold rainy night was discharging, system usage was greater than alternator output.
JimTR4 TR4/4A Battery recommendation Triumph 11
DornTRoriginal TR2/3/3A TR3 Battery Recommendation Triumph 9
J Battery Recommendation Austin Healey 1
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
