Attaching Rear Wings
dougsmarkIII
What method did the factory use to attach the rear wings on BJ8's at the shut face? One side of my car has pop rivets and the other side has pop rivets and a few plug welds. Both wings have been off before and some repairs done. I'm restoring the Healey and trying to use correct fasteners and methods. Thanks.
Doug
Keoke
Hi Dough, The rear wings were attached at the shut face panel utilising 8 flat head machine screws,flat washers,Lock washers and nuts on each side-Fwiw--Keoke
Johnny
:iagree: That is correct. The heads of the screws get painted body color, even though most of them are covered up with the aluminum facing and rubber windlacing. The nuts can barely seen from behind by looking into the wheel well.
dougsmarkIII
Many thanks guys. The wings are off at this time and I'm replacing the metal at the attachment edges on the shut faces and the lips on the wings because of too many large holes from drilling out welds and pop rivets.
Doug
dougsmarkIII
I have a workshop manual. Don't know if it's an original workshop manual. I'll have to take another look. It is not the Haynes, I do have that one too. The car and the manual is 70 miles from me today at my Brother's shop in Deer Trail, CO. He has a lift and well equipped body shop. Been scraping, grinding, sanding, removing paint and applying epoxy primer to the frame for the last several days. The original color was Colorado Red, previous owner changed it to the golden beige covering up too much bondo. The frame was left red however. Replaced the lower panel on the front shroud.
Photo of the 66 BJ8 with primer and sanding guide coat sprayed on.
Left rear work.
Doug
Keoke
richch said:
This is thoroughly covered and listed, accompanied by a photo in the original workshop manual.
Rich!!
You mean that book with all the fingerprints inside that says
"Austin-Healey 100 6
3000
"Workshop Manual" And use to be blue but is kinny dirty now too.---Keoke :laugh:
richch
Ya,ya, that's the one!
Now that it's in front of me the picture is on page P.3, and it's Fig. P.5. Technically the illustration is of an early BN1 shut face but the fasteners here are all identical.
Keoke
:thumbsup:--Keoke-- :laugh:
dougsmarkIII
Okay guys, looked in the workshop manual. LOW and behold There was the photo of the eight screws on the shut face just like it was stated. Didn't know the manual had that sort of detail. I just might take a look in the manual before I ask a question next time. But don't count on it. I want to check out the knowledge here. Update. Got epoxy primer on all of the frame today and lower body above the frame. Sure glad to get rid of all the red. Rear seats are out and have the primer on the bottom of the pans also. Will paint them black.
Doug
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
J Attaching new BJ7 Dashboard To Body Austin Healey 7
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
T TR4/4A Attaching headlight trim ring Triumph 6
M Attaching Info Plate to Engine Spridgets 1
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
Rut Attaching Hardura Spridgets 2
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
Rob Glasgow Attaching a video Austin Healey 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
J Need help attaching photos FORUM Navigation Questions 2
Brosky Wedge TR8 Seat attaching bolt measurements Triumph 13
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
Tinkerman TR2/3/3A TR3A Dash Clamp Attaching Point Triumph 10
S TR2/3/3A heater attaching piece tr3 Triumph 4
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
C Attaching door waist molding Austin Healey 2
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
jjbunn Re-attaching the hood Triumph 2
M BN4 Capillary tube attaching Austin Healey 2
R 3 point seatbelts, attaching? Austin Healey 9
Woodie attaching the bonnet Spridgets 5
N Re-Attaching Choke Cable to Pull... Austin Healey 5
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
AUSMHLY Attaching the quarter panels Austin Healey 1
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
B Rear Brake Cylinders Austin Healey 4
