Attaching new BJ7 Dashboard To Body
Jersey
I am replacing a my MKII BJ7 dashboard ... currently there is a BJ8 dash that was installed by a prior owner at some point. Can anyone advise me on how the BJ7 dash is secured at the sides and top to the body? The illustration in the Moss Motors catalog doesn't show any brackets/parts to do this other than an "escutcheon retaining plate" (part 108) that appears to go in the top middle area of the dash.
Any advice or pics would be appreciated.
Jersey
healeyblue
Here is a picture of the side attachment. Does your car still have these curved ends still welded to the car or have they been cut to make the BJ8 dash work. I had to replace them on a car with a custom wood dash in order to put back the factory aluminum dash.
Wow, that's rough.
The early dash is held on with a total of five (5) screws; two (2) at each end, as Jim shows, and one (1) through the dash in about the middle, to a bracket on the scuttle.
The bracket in the center can just be seen above and the the right of the two (2) rivets on the steering wheel at about the 2:00 - 2:30 position
This may be a clearer picture of the LH-end fasteners...
J
Jersey
Thanks so much...I have to take the plunge and pull the BJ8 dash out to see what is left, but I suspect the curved supports were cut out...I guess I will have to have them fabricated and welded to the frame.
Appreciate the picture!
Jersey
vette
Here's some pics of my BJ7. You see the curved pieces on the ends and the small cream white plastic cap is covering the off center screw that screws into the brace. Its not factory original but then nothing I build is factory original.
J
Jersey
Before I go and try to have the curved support pieces fabricated can anyone tell me where I might find them as parts on line? I see nothing on Moss or the British catalogs. If someone has BJ7 parts car I would be will to purchase them if they can be salvaged?
Thanks
Jersey
red57
Call British Car Specialists in Stockton, CA. (209) 948-8767
They are stocking distributors for Kilmartin and will know if Kilmartin makes them. They also have a lot of 'used' stuff too.
If you aren't' familiar with them, Kilmartin makes the best quality replacement meal pieces I have used.
Dave
Duane_Rhynard
Thanks
Jersey
Jersey,
Kilmartin makes the parts in Australia, you can purchase them:
Kilmartin at https://www.kas-kilmartin.com.au/KAS Austin Healey Parts Description.htm (Scroll down to AH295)
or in the US from BCS at https://www.britishcarspecialists.com/KASCatalog/ (Go to Cockpit Area, then Dash)
J Attaching BJ7 Oval Chrome Dash Molding Austin Healey 6
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
J Attaching BT7 Dash Facia Panel Austin Healey 2
Cutrog1 Attaching pictures while editing FORUM Navigation Questions 7
T TR4/4A Attaching headlight trim ring Triumph 6
Popeye TR4/4A Attaching rear of seat to seat slides...? Triumph 3
M Attaching Info Plate to Engine Spridgets 1
Gerald_Gordon TR4/4A Attaching badges without using a badge bar Triumph 5
T TR4/4A Attaching top dash pad on a Tr4a Triumph 8
Rut Attaching Hardura Spridgets 2
F J hooks an wing nuts for attaching hard top to body BT-7 - anyone got photos? Austin Healey 5
Rob Glasgow Attaching a video Austin Healey 1
B TR2/3/3A anyone help me identify the screw attaching seat slide to the floor? Triumph 8
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
J Need help attaching photos FORUM Navigation Questions 2
Brosky Wedge TR8 Seat attaching bolt measurements Triumph 13
Tinkerman TR2/3/3A Attaching the temp capillary to the fuel line. 3A Triumph 13
Tinkerman TR2/3/3A TR3A Dash Clamp Attaching Point Triumph 10
D Attaching Rear Wings Austin Healey 9
S TR2/3/3A heater attaching piece tr3 Triumph 4
crya Tricks for attaching door pulls on BJ8?? Austin Healey 8
C Attaching door waist molding Austin Healey 2
amcboy TR6 Question about TR6 top velcro attaching... Triumph 3
jjbunn Re-attaching the hood Triumph 2
M BN4 Capillary tube attaching Austin Healey 2
R 3 point seatbelts, attaching? Austin Healey 9
Woodie attaching the bonnet Spridgets 5
N Re-Attaching Choke Cable to Pull... Austin Healey 5
AUSMHLY Attaching the quarter panel Austin Healey 6
AUSMHLY Attaching the quarter panels Austin Healey 8
AUSMHLY Attaching the quarter panels Austin Healey 1
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
