Announcing a Finished 1959 BE Sprite
mxp01
All:
I am very pleased to announce the completion of this 1959 BE Sprite. Finished in Old English White, this car is the Ray Evan's creation "Whitephrog" with the finishing touches done by me, my son Cade, my friend Paul Nation, and some final, finishing work by JD's British Cars in Nashville, TN.
The car is as close to original as possible. With the exception of the red interior carpets, I think this car is concours grade. It has a rebuilt 948, smooth case transmission, HS1 carbs, a steel fuel line, mechanical fuel pump, and many other period-correct details. Nearly everything on the car is a result of Ray's meticulous work (I primarily did assembly). It also has an essentially complete tool kit,
The hard top is a new top purchased from Rodger Ward in California. It has the original rear glass, with new seals and clips courtesy of BugeyeGuy. The car has the proper bow and soft top (not in the car at the moment), as well as tonneau, As a bonus, I have a complete 1275 with rib-case transmission (for a future iteration of this vehicle) on a roller stand in the garage. I also have a Folchi-restored Judson supercharger, a 948 (sequence #10341) that is being rebuilt with the assistance of Hap Waldrop (for yet another iteration of the car). The only liberty I've taken with the car was to add an auxiliary horn purchased from Moss (which, I believe, were dealer accessories at the time and that these are proper replicas).
I am planning to take the car to the Moss meet in Petersburg in June. Hopefully, I might see some of you there.
Mike Pennell Sprite Done 11.jpgSprite Done 6.jpgSprite Done 3.jpgSprite Done 3.jpgSprite Done 9.jpgSprite Done 4.jpgSprite Done 13.jpgSprite Done 8.jpg
JPSmit
absolutely gorgeous! well done! :cheers:
Nelson
Looks great. I will be at the Moss meet with Little Mo so i will see you there then.
nomad
Very nice Mike!!
May I ask you a couple of questions? 1: Is the carpet from Moss and 2: I'd like to know more about the hard top. Google Roger Ward doesn't give much.
Thanks!
Kurt.
Pythias
Do enjoy it.... ... . I'm glad to hear you have other iterations planned.... I have known of at least two if not three other completely stock restorations being completed. It had taken the owners years of planning and parts acquistion. (IRIS was one of them, from .... jeez I forget his name down in Texas and another locally in Portland Oregon. Fabulous cars, but...
It didn't take long for them to want to either pass them along to the next guy OR modify them. They have reported that they just aren't that much fun to DRIVE. The brakes aren't very good and the engines are anemic. ... Absolute KUDOOS for completion, and enjoy taking (trailering) it to shows. You will surely receive accolades that are well deserved. .. .. Now.. a disc brake swop, the 1275, .. 5speed tranny, 3.9 rear end, . front sway bar, .. electronic ignition.. electric fuel pump.. you'll be ready to roll! :excitement:
M
mxp01
Kurt:
I am unsure about the source of the carpet. Ray might respond (if he reads this) as he was the one who sourced the carpet.
Regarding Rodger: I found him through some pretty extensive internet research when I stumbled across some minor web site that hosted an owner's forum. I think he looks periodically at the forum. If you search R.L. Ward Healey Restorations in Prather CA I think you will find him. The top is new and Roger has everything - including the mounting brackets and a plexiglass window for the rear. He is very, very helpful.
Mike
M
mxp01
Bill:
I think I'm in agreement with all your sentiments. I owned a BE with a 1275 & Weber carb that was significantly quicker than this current iteration. However, with this car I kind of hit the jackpot as it came with the 1275, electrical upgrades, etc.
For the time being I'm going to run the near-concours version. In the future I will do the swap to the 1275 and really get going.
Rut
Ray did a beautiful job on Whitephrog and was a serious student of original bugeyes! He helped me from my first day on this forum with everything from looking at potential candidates for restoration to supplying knowledge and parts for my car. Im thrilled to see Whitephrog complete and to a degree that would make anyone proud! Congratulations on a job well done.
Rut
Jim_Gruber
to see Whitephrog went to an owner that was able to fulfill Ray's Vision. Well Done.
drooartz
Very nice indeed. :cheers:
I can only hope that my poor little Penny will look as good some day.
Whitephrog
Material for the carpet may have come from Stock Interiors. I will check. Had a local upholstery shop do the work.
Whitephrog
Wow Mike! Glad to see the engine compartment was it should be. Especially like the period Sport coil back in place. Glad to see the vacuum line still is there. That was a bit of a difficult find and reconfiguration.
M
mxp01
Thanks,Ray,but of course this was primarily your vision, I just put it together.I must also admit that it took much longer than expected, to the point I was contemplating just throwing in the towel and going with the 1275.
anyway, I have another question: I have a small bag with two small clips. Written on the bad it says "Clip, draught excluder." I don't know where these go on the car. Do you?
Mike
M
mxp01
Sit in your driver's seat and look at your dash. Above the dashboard is the vinyl covered trim piece with all the chrome screws. The clips fit behind the trim piece and are held in place by the nuts on the screws on either end (circled in yellow) The draught excluder fits in the loop of the clip.
I understand where they go. What does a draught excluder look like?
B Announcing: Midget 50th Logo & Poster Contest! Spridgets 0
MadRiver TR5/TR250 Announcing my TR-250 website! Triumph 15
SNClocks Finished! Spridgets 1
D Interior Finished Austin Healey 3
tomshobby TR6 Finally finished my custom steering wheel. Triumph 12
J TR2/3/3A TR3 Guy '59 project Basic body work finished Triumph 5
AHS TR2/3/3A Resto [almost] finished - first driving impressions Triumph 16
Sarastro T-Series Interior is about finished MG 11
B WOO HOO! Doors are finished! Finally got the panels on, door pulls, handles & cranks Spridgets 9
F TR6 Just about finished- 1970 TR6 Triumph 17
CZ_Dave THe Finished Project! Other Cars 5
Stinger TR4/4A 1967 TR4A Finished !! Triumph 22
D Seats are finally finished! Spridgets 11
M TR2/3/3A TR2 Project Finished Triumph 4
RickB "Finished" my rattle can paint job Spridgets 19
scoutll Finished the hardtop . What do you think? Spridgets 12
T TR4/4A Just finished retrofitting the TR4a w/sway bar Triumph 4
mountainman Finally after 2 1/2 yrs It's almost finished Triumph 37
D Just Finished the 66 Restoration Austin Healey 15
jaegzie Finished up my daytona 675. British Motorbikes 4
Tullamore Finished the Berkeley! Other British Cars 9
T block prep progress-slow and not finished yet-pics Triumph 3
Glen_B Finished Morris truck photos Spridgets 16
M Finally finished carpet job. Spridgets 9
AUSMHLY Youtube...Finished my 2nd video....007 Healey Austin Healey 16
Tinkerman Tranny Top Finished, YEA! Triumph 7
jackq 59 Bug just finished Other Cars 9
Got_All_4 Back Light Frame AKA Surrey Top IS FINISHED & PIC Triumph 11
RickB Steering wheel finished! Spridgets 4
Brosky Additional bling finished Triumph 24
Glen_B EFI is FINISHED!! Spridgets 10
B Finished Them Brakelines! Spridgets 13
regularman Finished paint photos Spridgets 21
J Interior Finished! MG 2
Simon TR4a Rebuild is finished! Triumph 7
budk1953 A few parts finished Spridgets 7
Brosky Heater case rebuild project finished Triumph 15
Sarastro Finished my electronic tach project Spridgets 7
vping Finished with some parts. MG 7
B Finished R/H Trumpet Repair on the '65 Today MG 5
C I finished paint the engine compartment tonight!!! Triumph 7
Brosky Finished trimming carpet around roll bar Triumph 4
M Finished my motor MG 8
1 Finished leaf springs + question MG 6
RobSelina DIY rear tube shock ideas [finished w/ pics] Spridgets 18
jlaird Just about finished here Spridgets 3
A Winter project finished today!!!!! Spridgets 10
G Finished my alternator and tachometer conversion Spridgets 3
jerrybny Heated Garage Finished Triumph 13
