TR4/4A Selector shaft seals
clanofwolves
My ‘62 TR4 has always had issues leaking oil at the selector shaft seals, and replacing the O-rings didn’t do squat as the plate seems to be a pathetic mate for the O-rings. Have I been missing something? The exploded parts diagrams show what I have, but this cannot be what was expected (gear oil running down and getting on the exhaust. Assistance and thanks in advance are freely given.
TR3driver
Great Pumpkin - R.I.P
It appears that the original rings were not round, but either oval or rectangular in cross section. The cavity is too deep for modern round O-rings to fit snugly.
Herman van den Akker once told me that he machined brass washers to fill that gap. What I use are " PTFE backup rings" from MMC. (Plus the O-rings of course.)
https://www.mcmaster.com/9560k53
TomMull
On mine the center rail had rough spots, presumably from the staking process when the end was attached at the factory, which were exactly where the o-ring rides. I smoothed them out on the lathe but a file would work too. I'd be interested in knowing if others had this issue. My TR3 transmission did not.
I also used backup rings, as Randall suggests but I'm quite sure the real culprit was the shaft. (Quite sure I have some left over and can mail the to you. PM if that would help.)
Tom
Graham H
The only thing that I have found that works are quad rings, the size you need is QR-112 ID1/2" OD11/16" they will stop the oil leaking.
Graham
CJD
While you're working on it, double check that the air vent on the tail housing is open. If the vent gets clogged the tranny will leak no matter how good your seals are.
TR3driver
MMC has them
https://www.mcmaster.com/90025k226
Vent hole is in different places on different gearboxes; likely it's possible to assemble a mix that doesn't have one.
TR3driver
You can try asking MMC; used to be they would break a bag/box for a "modest" charge, but the charge usually wound up being as much as buying the box.
W TR6 Replacing seals on selector shaft '74 Tr6 Triumph 6
Simmo MGB Gearbox Selector Shaft Tensioning MG 2
P TR2/3/3A TR3 shifter popping out of selector shaft Triumph 10
AUSMHLY BJ8 selector shafts and forks condition Austin Healey 2
T TR2/3/3A How is selector fork detent positioned relative to top cover overdrive svitch? Triumph 6
NutmegCT General MG Wilson pre-selector? MG 2
B Problem with BJ7 gearbox selector Austin Healey 17
A Overdrive Help 3 & 4 Gear selector switch faulty? Austin Healey 10
C TR4/4A Rocker shaft spacer clearance with pedestals Triumph 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
WHT Rocker Arm Shaft Replacement Austin Healey 21
D XK150 Transmission Input Shaft Jaguar 1
AUSMHLY 1st Motion Shaft Bearing Austin Healey 7
Rut MGB 62-67 upper MGB steering shaft MG 3
G Installing New Rocker Shaft Assembly Austin Healey 3
D Spedo shaft direction Spridgets 6
Michael Oritt Propeller Shaft Hardware Austin Healey 6
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
M TR6 Redesigned Steering Shaft TR6 restomod Triumph 4
T MG Midget 1500 crank shaft pulley Spridgets 0
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
AUSMHLY Bad 1st Motion Shaft or Mainshaft Symptoms Austin Healey 13
AUSMHLY 1st Motion Shaft Play Austin Healey 3
R TR6 Drive shaft orientation Triumph 3
S TR2/3/3A Replacing the cam shaft Triumph 27
W BN1 Gearbox First Motion Shaft Austin Healey 0
S Removing Overdrive Shaft Lever Pin Austin Healey 7
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
P Wanted BN1 can shaft Austin Healey Classifieds 0
S Axle Shaft Installation Difficulty - Help Sought Spridgets 8
C Bugeye propeller/drive shaft- universal joint Spridgets 1
Walter74 Kent AH4 cam shaft Austin Healey 18
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
L TR2/3/3A Drive shaft question Triumph 5
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
M MGB First Motion Shaft MG 5
J General TR Cam shaft upgrade????? Triumph 3
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
J TR2/3/3A Triumph TR3 cam shaft measurement Triumph 2
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
steveg Steering rocker shaft - chemical rebuilding Austin Healey 3
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
R Center Gearbox Input shaft bearing Austin Healey 9
B TR4/4A Transmission Input Shaft Clearance Problem Triumph 16
S TR2/3/3A Clutch cross shaft bushings? Triumph 5
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
