General TR Spray bomb
PeterK
Went into my garage today and found the ramp on one side of the lift sticky and shiny with some clearish looking something. Then I saw it. A Rustoleum inverted marking can, for laying out lines on grass fields etc. high visibility pink that blew out out it's can. Was on a shelf for a year or so about 5 feet off the ground. So what was on the lift. My 3A. $hit. If the lift was up, there would have been no damage done.
I got right to work. It covered the driver side apron, nearly the entire hood, mirror, front fender, bumper, cowl some. 1st tried 3M adhesive remover that also removes bugs and tar to pick off the clearing solvent. It dissolved most of the spray (it apparently just happened before I discovered it), I had to pick the pink specks off, some remain, more that I haven't yet found. Then I washed it off with a wet sock and used the 3M again. Then I used some 3M swirl remover. Getting there but the paint has clouded a bit so next I'm going try my Porter Cable polisher next. It's not a trailer queen but a nice 3.
Throw away your old paint. I walked past that can every day and should have reached out and trashed it. Most of the pink leached out around the bottom of the can and did not get sprayed, thankfully. I'd rather be driving.
PeterK
PeterK
Got it done. Looks so good that the rest of the car now looks neglected.
CJD
What a freak deal!?!
If your finish is urethane, then you can go right to laquer thinner. The urethane is inert to it, but all spray bombs are not. Of course, if your finish is old laquer or enamel, then don't use thinner!!
Gliderman8
Your post timely... just yesterday I started pulling old cans of spray paint off the shelf in my shop in an effort to clean it up. So glad you got the pink off your car. I'm sure it was a lot of work but it had to be done.
PeterK
PeterK
I really can't believe it all came off and looks better since it just had a nice hand polish.
kjman55
Thanks for your post PeterK. I never would have expected that . I just packed my spray cans into a sturdy plastic box with a lid. so glad your car was not permanently marred.
TomMull
Even better, get and old metal file cabinet. I get them at the State of NH surplus materials auction where a lot of four goes for about $20. All my paints, solvents and other nasty stuff goes in.
Tom
PeterK
PeterK
PeterK
PeterK
Could have been a lot worse if I hadn't noticed right after it happened.
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S TR2/3/3A over spray Triumph 18
KVH General TR Painting the Engine Compartment with Spray Can Triumph 3
D General Tech Spray can shaking Triumph 4
dcoplan Custom color in a spray can? Spridgets 6
S TR2/3/3A spray the paint Triumph 13
Gerard Spray on Chrome Spridgets 33
angelfj1 3Mâ„¢ Paint Defender Spray Film Restoration & Tools 2
S Cold galvanizing zinc spray Restoration & Tools 5
bighealeysource Anyone use the HF HVLP spray gun # 66222 -$35.00 Restoration & Tools 2
D "Freezing Spray" Penetrants Restoration & Tools 9
wangdango Skuffin exising paint/for re spray? Austin Healey 5
B Spray paint tip Restoration & Tools 2
pjsmetana POR-15 & brush marks? Spray Version? Triumph 26
B Anyone have a favorite Paint spray gun ? Restoration & Tools 7
TonyPanchot Black spray from exhaust Triumph 9
tweety Dipstick oil spray/leak/ooze/whatever Spridgets 5
R Samba link paint removal spray MG 62
TR6oldtimer TR6 Spray painting a TR6 engine compartment comments Triumph 26
N Metal spray fender repair Triumph 16
Morris Copper spray and head gasket instructions??? Spridgets 5
Bruce_B Two-Part Catalyzed Primer in a Spray Can? Spridgets 1
MadRiver Cleaning up 3M adhesive spray? Triumph 18
M over spray removal Jaguar 6
T Anyone every spray paint/primer with one of these? Triumph 34
R Source for spray cans of touch-up paint? Triumph 12
T Spray booth rental in SoCal Triumph 0
beaulieu spray clear over bare metal for primer ? Restoration & Tools 10
C Signa Red in Spray Can??? Triumph 8
S TR2/3/3A $10 in spray paint vs. TR3's engine bay Triumph 10
S Spray-can engine bay painting effort Triumph 10
Simon TR4a Clear spray-on stoneguard? Restoration & Tools 2
Z Copper spray and coated head gaskets? Triumph 0
G Spray Painting Restoration & Tools 10
P Gray spray paint Jaguar 1
A Orange spray detailing stuff Restoration & Tools 0
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
S TR2/3/3A rebuilding bomb nose starter Triumph 9
HealeyRick This Bugeye's the Bomb! Spridgets 2
M TR2/3/3A Bomb style starter question Triumph 10
M TR2/3/3A Rebuild early bomb style starter TR3 Triumph 3
Strapping_Lad The Time Bomb! Re: '66 in San Diego Spridgets 16
