Fuel issue ?
hama61
Hello
Today I took the car for the second day out ( after she didn't dirve for approx three years). Yesterday during the first drive of approx 20 miles all went well. ( Car was for 4 years not on the road)
This morning i made another ride for approx 20 miles as well. This ride went without problems. After a stop of one hour I decided to take another short ride. The car started well but after a quarter mile just making a turn the engine stopped.( when i openend the bonnet I noticed, that you could clearly see the vapours coming out the carberettor area closest to the firewall) . Tried to start her again and again initially without success. As when the car turned on It was only for a second or two. I was just thinking to phone home, if the car wouldn't start during this last attempt to have the car towed home.
With this last attempt when turning on the ignition the fuel pump was ticking 4/5 times longers than usual but in the end the car started and drove without problems ( No idea what other problems will follow )
Are there any ideas, what it could have been and how to solve this when it will happen again
Harry
LarryK
How old is the fuel?
H
hama61
Fuel tank was for three years 1/6 th filled made some attempt before to start. Was drained prior to filling again with fresh gasoline
LarryK
Might take carb floats and clean or replace rubber needle seats and flush passages. Possibility of old fuel in lines sticking seats. Clean fuel does not always clear carbs. Replace or clean in line filter. Since it ran decent twice, not looking at ignition. Spark plugs can foul on old fuel mixture. If clean and still issue, check points.
bdcvg
Yep , if there was any ethanol in the fuel You now have gelatinous blobs floating around the fuel system.
H
hama61
Gasoline ( in the Netherlands Euro 95 contains 3-5 percent bio-ethanol) some brands Euro 98 doesn't contain any ethanol at all
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
G MGB Starter and fuel issue MG 6
Joe Schlosser 60 BE Fuel gage issue Spridgets 18
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
M_Pied_Lourd TR2/3/3A Fuel Delivery Issue Triumph 27
B TR2/3/3A Fuel gauge issue 60 TR3A Triumph 13
S TR6 Gold stars for TR3Driver&NutmegCT: it's a fuel delivery issue Triumph 9
J 1500 mg midget fuel issue Spridgets 2
S 1960 Fuel Pump Issue Austin Healey 5
M MGB MGB fuel pump issue MG 17
Henson80MGB Newbie w/ low fuel pressure issue MG 11
M TR6 TR6 Fuel Delivery Issue Triumph 18
T Fuel Issue British Motor Corp 3
bugedd Electrical issue, with dancing fuel gauge! Spridgets 11
S MGB-GT MGB GT ingition or fuel issue MG 1
lbc_newbie 78 Midget - fuel issue or distributor?? HELP! Spridgets 57
S Fuel or Spark Issue? Triumph 30
B Weird Fuel Pump Issue MG 1
Nunyas Fuel supply issue... MG 8
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
