MGB MGB fuel pump issue
mmotors
I have a 1964 MGB that had a original SU fuel pump that worked fine for years after I cleaned up the points. I did leak very slightly so I decided to replace the stiff diaphram and points with new parts. I set the points as per the manuel and unscrewed the diaphram until it just flipped over and then one more turn. Seemed to work fine at first, but stops at times and leaves me sit. Let the car sit for a half hour or so and it runs again. I tested with the pump out of the car and can get it to stop by placing my finger over the suction inlet. I can even remove my finger and it still wont pump until I shake or hit it. Any ideas why??? Thanks
Platinum
:lol:
Dave will get ya up and running.
As a hint, just crank the diaphragm screw down another few turns.
...or just go with a ~better~ pump from Dave. :wink:
Tim_Creger
Member
I have the same issues, and am looking to try something else in my car. Has anyone any experience with a Carter p60504 inline pump? I've a lot of bad stuff about Facet pumps, and I am not going for original appearance or sound, so would consider just about any affordable electric add-on that will provide reliable service.
Tim
Brinkerhoff
The correct procedure is in the shop manual . Fit the rollers , screw in the armature in until the throwover ceases. Screw it back a sixth of a turn until "throwover " occurs . Then "two thirds of a turn" out. Make sure the points are centered. You haven't adjusted it properly. The Facet pump ( $45 at NAPA) works best mounted on an MGB rear gearbox mount Moss # 413-050 for noise, and pointed slightly uphill as it works best to push fuel. Its a good pump too and will run quietly with the gearbox mount and not produce too much pressure which can be a problem with aftermarket pumps. Kevin
M
mmotors
I found that the diaphram rod was bent a bit and I straightened it. That may have caused the pump to stop? I also noticed that the new points were pitted a bit and suprised that it would have done that with only about 40 or so miles. I didn't replace the condenser- could that be bad? Or do they not work at all when the condenser goes bad?
Thanks, Shawn
David_DuBois
Shawn - The capacitor (condenser) going bad will not stop the pump, but it will compromise the arc suppression circuit, which in turn will cause the points to burn prematurely. I agree with Kevin, it sounds like the adjustment are not set correctly, but you could also have other problems with a pump that old. It is hard to asses the problem without seeing the pump.
Cheers,
Platinum
IMO the condensor was already tested... burnt points indicate it failed.
The low pressure Facet has been a great replacement in many cars here, the Carter P60504 as well. I've the Carter in my personal Alfa, supplying two 40 DCOE's and a Facet in the MGB (been there for YEARS) running SU's first and now a 40 DCOE. No problem with either.
M
mmotors
So far so good. It has been running well since I straighten the diaphram rod, cleaned up the points with some sandpaper, and when I reassembled the pump I pulled the diaphram upward by holding it up with a screwdriver as a spacer (some suggest not to do this). I didn't do that the first time.
Weird thing is, now it ticks all the time (maybe one tick per second). It never seems to get to the pressured point where it stops. Any thoughts why (no it isn't pouring fuel on the floor)?
What is normal burning on the points?
David_DuBois
"now it ticks all the time"
Could well be a bad check valve, either inlet or outlet valve. It could also be caused by an air leak on the inlet side of the pump (anywhere from the pickup tube in the tank, the fuel line from the tank to the pump, or in the pump itself). Disconnect the fuel line at the carburetor and direct the line into a jar, marked at the 1 pint level. Depending on what model of pump you have, you should get 1 pint of fuel in either slightly under 1 minute for the early pump, or 1 pint in just under 30 seconds for the later pump. The stream of fuel should not have any bubbles in it.
Cheers,
M
mmotors
I'll have to check the valves. I noticed the valves have a smooth and rougher side- perhaps I switched them around? Which way should they go?
Ever put in a Transient Voltage Suppresser in place of the condenser? If so could it be purchased at Radio shack?
David_DuBois
Shawn - The smooth side of the disk goes against the valve seat. You might want to lap the smooth side of the valve disks on some 600 grit sandpaper on a piece of smooth steel or glass to get any grove out of it.
It is doubtful that TVSs are available at Radio Shack, there are several hundred different voltage and power values for TVSs. You need on that has a maximum voltage cutoff of around 30 - 40 volts.
Cheers,
M
mmotors
Thank you for all of your help. I will clean them up. The valve works as a check valve right? Allows fuel to go to the outlet line and keeps it from running back? So the smooth sides would both be facing the same direction inward toward the pump?
David_DuBois
mmotors said:
Found this article: https://www.chesapeakechaptermgtclub.com/documents/FuelPumpTuneUp.htm
Can this diode be used in a MGB fuel pump? I see moss only sell a diode- could it be the same one?
That diode listed in the Chesapeake MGT Club will work, although it will slow the pump down somewhat.
I see the diode shown in Moss but not listed in their price list and you could need a different end cover if you were to use that.
e-mail me at SUfuelpumps@donobi.net
Cheers,
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
E MGB 1965 mgb fuel pump removal MG 2
G MGB '71 MGB fuel pump MG 21
P MGB 1980 mgb fuel pump MG 3
M MGB 72 MGB Fuel Pump MG 5
Erica MGB Carburetion and MGB fuel economy. MG 0
P MGB Early MGB fuel tanks MG 4
Flash_Harry MGB MGB '74 B-GT with fuel problem - SOLVED [I think!] MG 4
O MGB 1975 MGB No Fuel to the filter MG 2
G MGB Fuel sender '71 MGB MG 9
rggav MGB 65 MGB fuel filter MG 3
wkilleffer MGB Insulating MGB fuel lines MG 4
M MGB MGB fuel tank/ VIN number MG 5
S MGB-GT MGB GT ingition or fuel issue MG 1
Jayrz MGB Fuel Guage Inop, 64 MGB MG 3
C MGB Fuel guage '78 MGB MG 8
R6MGS MGB MGB Fuel backing up into charcoal canister MG 16
S MGB-GT MGB GT fuel problem MG 1
boxofparts MGB 79 MGB Fuel Level Sending Unit MG 6
tony barnhill Roll Cage & Fuel Cell in MGB GT Racing 10
Camshaft MGB-GT MGB/GT Fuel Problems MG 11
don62 MGB MGB 76 lack of power/fuel consumption MG 21
philman MGB mgb fuel guage MG 6
sonuvagunsmith MGB 72 MGB Fuel and temp guages MG 8
kyreb1862 MGB MGB Fuel Injection? MG 13
R6MGS T-Series Late MGB fuel cut off switch MG 5
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
Bret MGB "Finally, A Fuel-Injected MGB" MG 18
Glennyboy MGB MGB Fuel Injection MG 5
P MGB 1979 MGB NEWBIE fuel tank replacement MG 7
8 MGB Locking Fuel cap for MGB MG 8
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
