MGB Fuel guage '78 MGB
clyderedmond
As unlikely as it seems I have absolutely no idea of where to begin to check my now inoperable fuel guage. All was well until I took the old girl out for a spin yesterday. I noticed at once that the reading was on empty. I drove to the filling station to top it off since fuel theft is always a possibility. Having eliminated that, I am now ready to do some work but thought it might be prudent to ask the order in which one should check these things out. Any help would be appreciated.
Thanks,
Mike
First place to look is on the sending unit's electrical connections. Make sure that they are clean and tight. The sending unit is located on the side of the tank itself, on the right side of the car. You can check all connections without removing the unit from the tank.
bob67bgt
Most of the time it will be at the sending unit. I would remove the green wire from the sender and touch it to ground with the key on. Have someone else look at the guage . If it starts to move then its at the tank. With a full tank zero your trip odometer and run abotut 200 miles. Then jack the car up from the right side and remove the sender.Jacking up from the right side will move the remaining fuel from the sender unit side. The float may have sprung a leak or the sender went bad. Also be sure the ground wire is attached to the sender if your year has one. Thats where i would start. Also gas eats black top pavement! Do this job with a bucket ready in case you get great mileage and fuel still runs out after the 200 miles. Bob
C
clyderedmond
I checked the wire out - only one brown wire into the sending unit. A bit of corrosion on the copper, so I tried to clean it off and no joy. Well it's too hot to deal with this now so I'll wait for Monday.....Thanks for the suggestions.
Some hours later...tried again and we are all set. Thanks for the help-. I guess some die-electric grease is in order.
C
clyderedmond
Yes, the temperature guage works fine. The problem was corrosion at the contact at the sending unit. Cleaned it up and all is working fine again.
WooHoo! An inexpensive fix!
:thumbsup:
Jayrz MGB Fuel Guage Inop, 64 MGB MG 3
philman MGB mgb fuel guage MG 6
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
B TR2/3/3A Fuel Guage Triumph 5
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
bugedd Fuel guage not working Spridgets 7
W Fuel guage interchangeable between AH, MG, TR? Austin Healey 11
R TR5/TR250 Fuel Guage Problem Triumph 10
S Temp and Fuel guage not working Triumph 4
M Fuel Guage Woes MG 2
tinman58 fuel guage Triumph 8
tinman58 fuel guage Triumph 3
jcatnite Fuel Guage Spridgets 9
Tinkerman TR 2 - 4 Fuel Guage Senging Units Triumph 3
jlaird Fuel guage repair-professional Spridgets 9
bugimike fuel guage for Jack Spridgets 11
TR674 Fuel Guage Triumph 3
L Temp and Fuel Guage MG 10
philman fuel guage sending unit MG 19
Woodie fuel guage not working Spridgets 8
curtis Fuel Guage Austin Healey 12
A fuel guage Austin Healey 5
T Fuel Guage non workee - suggestions? Spridgets 4
TypeRboy Fuel guage sender for Elans Lotus 0
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
