fuel guage
tinman58
Don't ask me how I know but my fuel guage does not work.
What is the best way to test it? I have a new sending unit and a new wiring harness, the guage was in a box with a bunch of other junk TR3A 1958
Dan
NutmegCT
TR3driver
Great Pumpkin - R.I.P
For a simple test, connect 12v to the gauge (between the B terminal and the case). With the tank (T) terminal open, it should read past full. If you short the tank terminal to the case/ground, it should read empty.
For more than that, check out
https://mgaguru.com/mgtech/electric/fg_01.htm
Although the resistance values are not precisely correct, they are close enough.
Geo Hahn
If you suspect the sending unit you can manipulate it with a length of wire suitably shaped to fish thru the gas cap opening and hook the arm of the sender. If the hook part is a big 'L' it can also be used to push the arm down. I use copper wire and make it long enough I'm not going to lose it in the tank if I let go.
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
B TR2/3/3A Fuel Guage Triumph 5
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
bugedd Fuel guage not working Spridgets 7
W Fuel guage interchangeable between AH, MG, TR? Austin Healey 11
R TR5/TR250 Fuel Guage Problem Triumph 10
S Temp and Fuel guage not working Triumph 4
M Fuel Guage Woes MG 2
tinman58 fuel guage Triumph 8
Jayrz MGB Fuel Guage Inop, 64 MGB MG 3
C MGB Fuel guage '78 MGB MG 8
jcatnite Fuel Guage Spridgets 9
Tinkerman TR 2 - 4 Fuel Guage Senging Units Triumph 3
jlaird Fuel guage repair-professional Spridgets 9
bugimike fuel guage for Jack Spridgets 11
TR674 Fuel Guage Triumph 3
philman MGB mgb fuel guage MG 6
L Temp and Fuel Guage MG 10
philman fuel guage sending unit MG 19
Woodie fuel guage not working Spridgets 8
curtis Fuel Guage Austin Healey 12
A fuel guage Austin Healey 5
T Fuel Guage non workee - suggestions? Spridgets 4
TypeRboy Fuel guage sender for Elans Lotus 0
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
