TR2/3/3A Fuel Guage
BobbyO
There have been several postings concerning calibrating the TR3 fuel guage using the MGAGURU method published by them; however there are several comments that the procedure is the same but the resistance is different. The resistance used in the mgaguru procedure is 68 ohms. If this is not the correct resistance, what is? To make matters more confusing, there have also been several comments to the effect that they have used this procedure with these resistances and it has worked fine. Should I consider this procedure to be adequate and go with it or continue to attempt to find the correct resistance for the TR guage?
Crankshaft
Earlier this spring I used the instructions you have to a very satisfactory result.
CJD
I used resisters laying around the house. (I know...I need to get a life if I happen to have resistors laying around!?!). I could not get exactly 68 ohms, but did get very close. It worked great.
But...if you are concerned, just put an ohm meter on the tank sender and measure with the float full up and then full down. You will then get the exact numbers you need for calibration.
B
BobbyO
I'll just attempt to find 68 ohm resistors. Resistors are not as readily available as the use to be. Not in this local anyway. My system is working fine but a friend is having problems. And, I have a couple of spare gauges I thought I'd check. As if there isn't enough to do on these cars anyway. By the way John, up until a couple of years ago I also had resistors laying around. I'm sure I got them in the '70s but got rid of them when I moved.
TR3driver
Great Pumpkin - R.I.P
That's my suggestion too, measure the sender you have. They aren't all the same.
Check eBay for resistor assortments. But don't forget that each resistor has a tolerance; they are practically never exactly the advertised value. For example, a 1K 5% resistor may be anywhere between 950 ohms and 1050 ohms and still be within spec.
Another route is to use variable resistors and set them with your meter (which hopefully ensures they will match the sender, even if your meter is off a bit). I have lots of them laying around (almost as many as Triumph parts, which in a way, they are); but you should be able to find a couple of cheap ones on flea-bay for not much.
PS it occurs to me that some people might not know: If you connect two resistors end to end ("in series"), the overall resistance is the sum of the two resistor values. So, for example, you could grab this kit from Amazon for $3
https://www.amazon.com/gloednApple-...499375354&sr=8-2&keywords=resistor+assortment
and connect a 22 ohm resistor in series with a 47 ohm resistor to get "close enough" to 68 ohms.
6TTR3A
I found a 0-200 ohm pot years ago. Made up a home-made dial in 5 ohm increments from 0 to 95 and it covers the resistance values for the scores of Smiths sidescreen tank units that I've checked over the years. Most Smiths FT 3331/02 units go from 2-5 ohms empty to 88-93 ohms full. Aftermarket ones seem to be lower range (10-80 Ω)
Frank
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
bugedd Fuel guage not working Spridgets 7
W Fuel guage interchangeable between AH, MG, TR? Austin Healey 11
R TR5/TR250 Fuel Guage Problem Triumph 10
S Temp and Fuel guage not working Triumph 4
M Fuel Guage Woes MG 2
tinman58 fuel guage Triumph 8
tinman58 fuel guage Triumph 3
Jayrz MGB Fuel Guage Inop, 64 MGB MG 3
C MGB Fuel guage '78 MGB MG 8
jcatnite Fuel Guage Spridgets 9
Tinkerman TR 2 - 4 Fuel Guage Senging Units Triumph 3
jlaird Fuel guage repair-professional Spridgets 9
bugimike fuel guage for Jack Spridgets 11
TR674 Fuel Guage Triumph 3
philman MGB mgb fuel guage MG 6
L Temp and Fuel Guage MG 10
philman fuel guage sending unit MG 19
Woodie fuel guage not working Spridgets 8
curtis Fuel Guage Austin Healey 12
A fuel guage Austin Healey 5
T Fuel Guage non workee - suggestions? Spridgets 4
TypeRboy Fuel guage sender for Elans Lotus 0
AndreL TR6 Conversion to electric fuel pump Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
