MGB Which exhaust mainfold?
I just bought a nice restored HIF4 setup on ebay... I know exhaust manifolds changed over the years, which one will I need to go with this setup?
Mickey Richaud
You'll need one to fit a '72-'74.
kennypinkerton
Will the 12Hxxxx number on them tell me which ones I'm looking at? I see many on ebay, 12H709, 12H3911, etc, where the date either isn't listed, or the seller says 1962-80, lol.
Mickey Richaud
I believe the one you want is the 12H3911. Will have to double check that.
kennypinkerton
I've been searching (off and on) all day... where would I find that exact info? It's not in any of my catalogs. I feel kind of silly that somehow I have limited myself to something only made for 3 years. My luck, lol. I hope hif4 carbs were the way to go over hs4. I guess anything would be better than the restrictive (and incomplete) zs setup I have now.
JPSmit
go with a header, better flow and easier to find.
kennypinkerton
They probably are, but steel rusts, SS is expensive, and I can get a cast iron manifold for about $100 shipped to me that still flows 100 times better than the abomination of a manifold that was on the 77.
Mickey Richaud
According to most, the factory manifold is actually as good as it gets. Keeps heat down in the engine bay and is quieter. Also, less chance of rust-through. And cheaper. They pop up on ebay fairly often.
Here's one; needs studs, but they all do: https://www.ebay.com/itm/Very-Good-...ash=item465d7482e8:g:CDUAAOSwNsdXRfEx&vxp=mtr
'nother one: https://www.ebay.com/itm/MG-MGB-EXH...ash=item1a23be089b:g:a5oAAOSw2xRYehR7&vxp=mtr
Mickey Richaud
The 12H3911 is what came on my '73, and when the header I put on it when I rebuilt it dies, it's going back on. :wink:
PAUL161
Only thing you can do to a B manifold to make it a little better, is to polish the inside and ceramic coat it. The original manufacture did a wonderful job on the design, it's as near perfect as it gets and the only reason to abandon the original manifold is weight, as in racing, every ounce counts. PJ
Joe Reed
You can use either exhaust manifold. Just make spacers to make up the difference in thickness. Quick easy way is to cut a couple of thick washers in half...or stack thinner washers if needed. Superglue will hold them together while installing them Once the nuts are tight they won't go anywhere...
kennypinkerton
Thanks guys.
image.jpgKenny,
beadblasted and checked for cracks.
Marv
Rut
Kenny,
Marvs manifold looks great, but if it doesn't work out try Michael Powell at Bell Auto in Northport, AL.
Rut
R installing Intake Exhaust mainfold Triumph 18
J TR4/4A Exhaust a tad too loud... Triumph 6
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
K TR2/3/3A Thick flat washers for exhaust manifold studs? Triumph 0
CARSINC Please Identify this Exhaust Header Spridgets 2
Patrick67BJ8 Traced down that elusive exhaust leak! Austin Healey 5
Walter74 AH Spares Side Exhaust Austin Healey 2
TomMull GT6 "Sports" Exhaust Triumph 2
Tim Tucker TR4/4A Phoenix Stainless Steel Sports Full Exhaust System Inc Manifold experience Triumph 3
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
K TR2/3/3A Exhaust pipe banging inside the cruciform? Triumph 8
B TR4/4A Exhaust Wrapping Triumph 8
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
T Exhaust Pipe Hose Austin Healey 9
B Stainless Steel Exhaust System Wanted Austin Healey 5
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
jfarris TR2/3/3A Exhaust Hanger Question Triumph 4
3 Exhaust Manifold/Headers BN2 Austin Healey 16
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
tahoe healey Exhaust Manifold Gaskets Austin Healey 5
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
nichola TR6 Stock exhaust sound... short video Triumph 4
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
60TR3A TR2/3/3A Exhaust System Recommendations Sought Triumph 15
B Exhaust Pipe Size Austin Healey 26
6 Exhaust Pipe Spridgets Classified 2
K TR2/3/3A Can heat from exhaust downpipe ..... Triumph 2
AngliaGT MGB-GT TT Stainless Steel Exhaust Re-Installtion Suggestions MG 2
Ripper01 SOLD-TR6 Dual Port Exhaust Manifold Triumph Classifieds 6
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
S TR2/3/3A Exhaust Systems Triumph 10
S TR2/3/3A TR3 has me stumped, it runs then dies over and over and the exhaust system was pulled Triumph 9
B TR4/4A General exhaust questions Triumph 17
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
F Exhaust Fumes in the Cockpit - BT7 Austin Healey 10
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
3 BN2 clutch pedal and exhaust downpipe Austin Healey 14
AUSMHLY Gasket, Inlet Manifold to Exhaust Manifold BJ8 Austin Healey 8
Zitch For Sale TR-4A exhaust manifold Triumph Classifieds 0
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
AUSMHLY Exhaust Manifold Flange Stud Austin Healey 13
AUSMHLY Exhaust leaks Austin Healey 14
PAUL161 T-Series MGT Exhaust Stud Thread Size MG 2
BLong63AH Removal of Intake and Exhaust manifold. Austin Healey BJ7 Austin Healey 24
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
