Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Will the 12Hxxxx number on them tell me which ones I'm looking at? I see many on ebay, 12H709, 12H3911, etc, where the date either isn't listed, or the seller says 1962-80, lol.
I've been searching (off and on) all day... where would I find that exact info? It's not in any of my catalogs. I feel kind of silly that somehow I have limited myself to something only made for 3 years. My luck, lol. I hope hif4 carbs were the way to go over hs4. I guess anything would be better than the restrictive (and incomplete) zs setup I have now.
They probably are, but steel rusts, SS is expensive, and I can get a cast iron manifold for about $100 shipped to me that still flows 100 times better than the abomination of a manifold that was on the 77.
According to most, the factory manifold is actually as good as it gets. Keeps heat down in the engine bay and is quieter. Also, less chance of rust-through. And cheaper. They pop up on ebay fairly often.
Only thing you can do to a B manifold to make it a little better, is to polish the inside and ceramic coat it. The original manufacture did a wonderful job on the design, it's as near perfect as it gets and the only reason to abandon the original manifold is weight, as in racing, every ounce counts. PJ
You can use either exhaust manifold. Just make spacers to make up the difference in thickness. Quick easy way is to cut a couple of thick washers in half...or stack thinner washers if needed. Superglue will hold them together while installing them Once the nuts are tight they won't go anywhere...
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
