Wire Wheel Question: PVC Tape
G
Hey guys, I have probably ordered a wire wheel for my spare tire compartment. I will get a Vredestein Sprint Classic 165HR15 tire, and a tube, and PVC tape for the wheel.
HOW DO I PUT ON THE TAPE?
Do any of you wire wheel folks have a photo of how the tape is installed. Obviously, it goes over the ends of the spokes, but I would LOVE to see a photo of what a proper tape-job looks like. (Remember whom you are dealing with here.)
As usual, thanks in advance.
bgbassplyr
Start at any spoke nipple and wrap the tape around and around the wheel until the nipples are completely covered. Since you are only doing one wheel, just wrap until the tape is used up. The point is to eliminate the tube becoming abraided by the nipples because the tube will tend to move and rub as the wheel rotates. The tape allows for this movement sans the abraiding.
dklawson
According to the folks at Hendrix Wire Wheel, the PVC tape is the preferred method now compared to the traditional 'rubber bands'.
I will be picking my wire wheels up from them next weekend and will ask about the rim tape. I thought they said it was applied in two places in two different widths.
Twosheds
Sorry, I don't have any photographs.
The British Wire Wheel rep told me that I should not stretch the tape when wrapping it, but to just wrap it without pulling it too tightly. He said to use two layers, if I remember correctly.
Platinum
My WAG would be the Teflon is less likely to generate heat/wear from frictional effect. The bands were supposed to be powdered with talc to reduce the friction, Teflon or PVC are kinda "self lubricating".
Again... just my WAG.
dklawson
My understanding concerning the bands is the same as the Dr.'s. I'll be sure to ask for confirmation when I pick my wheels up this weekend.
I'm 99% certain that the tires/tubes they are currently replacing on my wheels have duck-tape covering the spokes.
JohnB
Bronze
Is PVC tape the same as the black electrical tape or is the black stuff made from a diferent plastic? And is there any major problem with just using a good quality duct tape?
I am also putting new tires on some old rims, and being new to this game, am interested in any suggestions.
thanks......
Twosheds
thanks......
The British Wire Wheel rep was very insistant upon using only PVC tape. From this I assume that it must be different from electrical tape, but I can't tell you how it is different.
He very strongly said NOT to use duct tape. I think that this is because duct tape becomes hard with age and will chafe the tube.
dklawson
Sorry, I didn't mean to imply in my last post that duck tape was acceptable. The folks at Hendrix nodded when I told them that duck tape was probably what they'd find on my rims. However, they also said that duck tape was not a good choice... only slightly better than nothing.
LBCs_since_1988
right. Duct tape is BAD! I've seen old wheels where DPOs have used it and the tape "melts" into the nipple area. -Probably due to the adhesive failing. Use PVC or Rubber only!
Platinum
Duct tape will decompose kinda quick. Gets gooey first then brittle and dry. I'd use the rubber band & talc with little concern but PVC tape for sure. Regular "electrical tape" will slip, shrink, goo and generally make a mess too.
Geo Hahn
FWIW -- When I picked up a roll of PVC tape to do this (Ace Hardware) they had both 10 mil and 20 mil. Went with the 20 mil of course -- must be twice as good (was twice as expensive).
I used powder as well as the slick tape -- was careful to get a brand that was talc -- many now have corn starch which is likely good on a baby's behind but not in my baby's tires.
af3683
Can anyone tell please me where to purchase the PVC tape to wrap around my wire wheels in order to cover the spokes. I've gone to several hardware stores and they are not familiar with it. Do I have to go to a plumbing supply store? Any help would be appreciated. Thank you.
Art
dklawson
You could contact the folks at Hendrix Wire Wheel. They have a web site where you will find contact information. They will sell you rolls of the tape they use.
Geo Hahn
As I noted, they had it at Ace Hardware. Maybe they just don't recognize it by 'PVC Tape' as it does not say that on the roll. It's a big wide roll, shiny black tape with white letters: "Christy's 20ML".
JohnB
Bronze
Got my PVC tape from my local Ace hardware store. They knew exactly what I wanted when I explained what it was for. As I recall it was 20 mil.
JohnB
Bronze
Well I finally found it out in the barn.
It wasn't 20 but rather 10 mil and it's called "Ace Pipe Wrap -
anti corrosion". Come 2" x 36 yards and stock no 47097.
Made by Henkel Corp. and labeled on the tape as PVC, not on the package.
Hope that helps.
af3683
Thanks everyone. I plan on going to my local Ace Hardware tomorrow and seeing if they have any Christy's Pipewrap Tape in 20ml. I see that it comes in 2" width. Thanks again.
Art
RJS General TR Wire Wheel Spline Question Triumph 3
B TR4/4A Wire wheel question Triumph 10
P TR5/TR250 wire wheel question Triumph 3
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
S General TR Wire Wheel New Tire Installation Question Triumph 11
Lukens Wire wheel question. Triumph 14
Marvin Gruber MGA MGA wire wheel swap question. MG 3
K TR2/3/3A TR3A wire wheel hub splines question. Triumph 9
Tinkerman Wire Wheel Question, Kinda...... Triumph 8
bcliff Wire/Steel wheel axle question MG 8
A WIRE WHEEL QUESTION Triumph 7
tony barnhill Rear Hub to Wire Wheel Extension Question Spridgets 3
B Wire Wheel Question Spridgets 14
Todd78d Wire wheel cleaner Spridgets 1
K 1068 mkIII wire wheel rub Spridgets 1
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
W TR2/3/3A Wire Wheel Conversion Triumph 5
R Wire Wheel Fit Austin Healey 10
DocDup1 MGA Wire Wheel Hubs For MGA MG 6
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
P Wire Wheel Splines Austin Healey 10
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
M Chrome wire wheel questions Spridgets 5
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Wire Wheel Grommets Triumph 5
Raymond MGB Wire Wheel Tire Mounting MG 0
Raymond MGB Wire Wheel Cotter Pin MG 5
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
B General Tech Wire wheel sealing bands? MG 4
J For Sale Wire wheel set Triumph Classifieds 2
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
M TR2/3/3A Wire Wheel Splines Triumph 3
Zitch Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
S MGA wire wheel space saver spare MG 1
N Wire wheel hub removal & suspension tear down Spridgets 3
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 17
PAUL161 General MG Wire wheel balancing service MG 2
GTP1960 TR2/3/3A Hub extension torques? [for wire wheel] Triumph 4
S TR2/3/3A Wire wheel balancing Triumph 16
M wire wheel spokes "tuning" Austin Healey 8
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
J General TR Wire wheel sale pricing Triumph 18
J How to repair a tubeless wire wheel leaker ? Austin Healey 10
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
