Wire wheel hub removal & suspension tear down
NickCacci
I am tearing apart my wire wheel front suspension for an inspection and rebuild. After removing the wheel it appears that the dust cap is recessed in the hub with a 5/16 stud sticking out. How do you get the dust cover off and remove the hub? Also when trying to separate the A arm from the spindle I can't get the tapered pin out. I tried driving it out with a brass rod and hammer. And, the plug that goes over the fulcrum pin (it appears to be aluminum) is frozen. HELP
nomad
You will need to fo some improvising. To pull the hub cap how about a piece of strap with a hole drilled in it and bent at 90 degrees. Put a nut on and lever the hub cap out. There are ball joint pullers made but if you put a heavy hammer up against one side of the arm next to the taper and hit the other side with a slightly smaller hammer after loosening the nut of course, it should break free. As to the plug with the grease zerk in it, the whole assembly usually needs replacing anyway.
Kurt.
Randyz
Member
I wouldn't bother trying to remove the lower fulcrum pin. The A-arm is usually stripped out and the fulcrum pin is often seized. You'll probably want to re-bush the swivels, so you'll need to get a major front end kit. That will give you new king pins and new fulcrum pins. Now just buy new A-arms and you'll be good to go.
N
NickCacci
I had 2 sets of front suspension. After using heat and a cut off wheel I got it all apart. I used a cut off wheel on two of the fulcrum pins and pressed the piece of fulcrum pin out of the swivel pin. I was able to save one good swivel pin and two wishbones. All of the swivel pin bushings were tight. With new fulcrum pins the two wishbones were tight. Saved a few bucks but it took about a days work. It looks like it will be fun getting cotter pins back in when I re install the hubs.
GTP1960 TR2/3/3A Hub extension torques? [for wire wheel] Triumph 4
bighealeysource nut stuck on wire wheel hub on BN2 Austin Healey 18
K TR2/3/3A TR3A wire wheel hub splines question. Triumph 9
tony barnhill Rear Hub to Wire Wheel Extension Question Spridgets 3
tony barnhill Midget MkI Rear Wire Wheel Hub Spridgets 4
Baz Wire wheel hub removal...... MG 28
10musketeer Wire Wheel Hub Spridgets 6
SilentUnicorn HELP wire wheel hub removal Spridgets 3
K looking for a left front wire wheel hub MG 3
K wire wheel hub splines MG 6
RJS General TR Wire Wheel Spline Question Triumph 3
B TR4/4A Wire wheel question Triumph 10
P TR5/TR250 wire wheel question Triumph 3
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
Leatherman TR2/3/3A Wire wheel conversion question Triumph 19
Joe Schlosser Wire wheel Parts Free to good home Spridgets 0
M Chrome wire wheel questions Spridgets 5
S Locknut - rear wire wheel - torque spec? Austin Healey 15
jfarris TR2/3/3A Wire Wheel Grommets Triumph 5
Raymond MGB Wire Wheel Tire Mounting MG 0
Raymond MGB Wire Wheel Cotter Pin MG 5
BN6_2197 Question on rear brake drums BN6 wire wheel Austin Healey 15
KVH TR4/4A Front Wire Wheel Hubs Differ from Disc Hubs?? Triumph 5
B General Tech Wire wheel sealing bands? MG 4
J For Sale Wire wheel set Triumph Classifieds 2
maxwedge5281 wire wheel conversion to road wheels Austin Healey 21
CJD TR2/3/3A Wire Wheel Locating Collar 108942 Triumph 15
M TR2/3/3A Wire Wheel Splines Triumph 3
Z Wanted WTB - One good wire wheel for Spare [15x4.5] Triumph Classifieds 1
S MGA wire wheel space saver spare MG 1
KVH General TR Short Wheel Studs for Wire Wheels--Replacing Triumph 14
PAUL161 General MG Wire wheel balancing service MG 2
S General TR Wire Wheel New Tire Installation Question Triumph 11
S TR2/3/3A Wire wheel balancing Triumph 16
M wire wheel spokes "tuning" Austin Healey 8
S TR2/3/3A 155/15 Vredestein Sprint Classic on a 4.5" Wire Wheel as TR3B Spare? Triumph 6
S TR2/3/3A Lug nuts for wire wheel adaptors Triumph 3
J General TR Wire wheel sale pricing Triumph 18
J How to repair a tubeless wire wheel leaker ? Austin Healey 10
K Original "old" 1960'es Dunlop wire wheel paint code Austin Healey 7
K Original 1960'es Dunlop wire wheel paint code Jaguar 7
K 1960'es Dunlop wire wheel paint colour code Restoration & Tools 0
K General Tech 1960'es Dunlop wire wheel pint colour code Triumph 13
5 Bugeye wire wheel dust caps Spridgets 4
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
P New England Wire Wheel Triumph 2
D new member with wire wheel questions Jaguar 6
D new member with wire wheel questions Austin Healey 7
D neww member with wire wheel questions MG 11
D new member with spoke wire wheel questions Triumph 12
