Which Distributor
Mg_Bizzle
Im confused as to which distributer to use. I currently have one from a 1979 BGT, but according to peter burgess (how to power tune MGB 4 cylinder engines) its advances curves are wrong and no good. I don't wish to switch over to the chrome bumper dizzy as it would mean me changing my carbs too.
I have seen the 43D dizzy but as this is a car that is going to be used on the road wouldnt this make it run very lumpy.
Id like to try and avoid electronic ignition if possible so what are my remaining options?
My MG is 79, and I will be using the carbs off the 79 engine (HIF's I think?). I could be getting a weber 45 in distant future but for now im hoping I can use the HIF's and not need to buy older carbs which have the vacuum take off mine dont.
The engine is from around 71-74 (big valve head), its 1950cc, piper 270 cam stage 2 head, lightened flywheel etc etc.
Stewart
Contact Jeff at https://www.advanceddistributors.com/ He will rebuild and recurve the distributor for your engines specs. He does fantastic work and tends to have a very fast turn around.
It's not an issue to swap distributors around and an early distributor will work as well as a later one but you will want to have it recurved to match your engine. Carbs will not have to be changed to use a differnt dizzy.
Mg_Bizzle
Mg_Bizzle
Im no expert but the Burgess book mentions the chrome bumper dizzy taking a vacuum advance off the carbs instead of the carb manifold, this being one of the problems with my dizzy.
Thanks for the link but im in the UK, I will try and find a similar service this side of the pond though. Do you have a rough idea of how much he would charge?
Edit: Just took a look round the site, would I just need a "rebuild" or as this engine is quite different to standard would the work cost more?
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A Aftermarket Distributor Points and Terminal Bush leads? Triumph 1
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
P DM6A Distributor Question Austin Healey 9
A TR2/3/3A A123 distributor Triumph 5
AUSMHLY Distributor cap center pin melted Austin Healey 5
M Mallory Dual point distributor Austin Healey 0
K TR2/3/3A Distributor Caps Triumph 6
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
K TR2/3/3A The Distributor Dwell reading... Triumph 1
W Mallory distributor on '60 BT-7 Austin Healey 4
R TR2/3/3A Establishing distributor shaft end float Triumph 4
af3683 TR2/3/3A Distributor Clamping Plate Studs Triumph 15
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
BOBBYR Advanced Distributor Austin Healey 9
D BT7 Oil Leak at Distributor Austin Healey 5
H driving dog [gear] for distributor? Austin Healey 17
Csarneson 100-6 distributor questions Austin Healey 8
D BT7 Tri-Carb Distributor Cap Austin Healey 9
