where does all the oil go?
rdr952
My 6 runs great...I suppose that's why the carbs seem to lose enough of their damper oil to cause a poor idle.Any thoughts on why or what causes the oil loss?
RomanH
What year is it?
If you have the adjustable needles with fixed jet version of the ZS carb then you are probably having the same problem I have.
The adjusting screw which adjusts the mixture needle is supposed to have a "O" ring on it to prevent the oil from leaking around it and down the meetering needle. It needs to be replaced.
The Bently book does not address this and the Haynes carb manual states that the adjusting screw should not be reomved. But you can and the "O" ring and and the screw retaining ring are available from Moss or Victoria British.
There is a good article on how to do this in the "Technical" section of this site under carb rebuilding.
https://web.archive.org/web/20021203144249/www.buckeyetriumphs.org/index.htm
I am waiting for my parts to do this job. Should be here in a couple of days. I will let you know how it turns out.
piman
Hello rdr952,
I can't see why damper oil or the lack should affect your idle. The other thing is that it seems that it is commonly expected that the damper remains full of oil, it doesn't and does not need to be full. If you remove the damper piston and then replace and feel resistance as you re-insert it then it has enough oil.
Alec
CJD Where does the oil go? Triumph 9
G Where does my oil pressure line connect? Spridgets 4
M TR2/3/3A Where does this screw go? Triumph 6
B Tie Rod - Engine: What is it and where does it go? Austin Healey 12
KVH TR4/4A Long Speedo Cable for Overdrive--where does it get tied down? Triumph 7
M TR4/4A Where does this attach? Triumph 7
B Lower Steering Column Bush - Where does it go and how? Austin Healey 14
Tinkerman TR2/3/3A Where oh Where does the other end go? Triumph 4
Lbp TR2/3/3A Furflex Door Seal - Where does it go? Triumph 3
J MGB Name this part? Or , where does it go? MG 9
AngliaGT 4speedDatsun B210 - Where Does it End? Other Cars 4
M TR6 Where does this TR6 brake line go?[pic] Triumph 3
Got_All_4 Wedge 80 TR7 PI where does this go Triumph 7
richberman Where does this panel fit? Austin Healey 2
Brooklands Where does this part go? Triumph 8
I Does anyone know where to get some of these? Spridgets 5
Tinkerman Where Does YOUR Tube Go? Triumph 12
Newkie Where does the commision no. badge go? MG 2
F Where does this wire go ? MG 1
davidk Where does it end.... Triumph 14
Bruce_B Where does hose from timing cover go? Spridgets 6
Bruce_B Datun 5 speed--where does the Speedo cable attach? Spridgets 26
R BJ-7 Steady Bracket? What is it & where does it go Austin Healey 20
mjobrien Flasher for BN1 - Where does it mount? Austin Healey 8
PATR8 Wedge Where does one find a Rimmer Aley Bar for TR8 Triumph 13
tomshobby Where does it end? Triumph 24
J Spitfire '70 Spitfire MK3 - Where does this attach? Triumph 10
vping Where does this go? MG 9
Basil Where does this go? Jaguar 11
E Does anyone know where this XKE ended up Jaguar 6
P Where does this go? Sunbeam (Rootes) 4
B MGA Where to Buy, What to Buy? Axle Nut MG 9
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
A Where to get key blanks for SD1 in the U.S.? Rover / Land Rover 5
F Off Topic Personal update/ Where is Frank? Triumph 4
Basil Where's Walter? Spotted 8
Q TR2/3/3A Where to start?! Triumph 13
jlaird MGB Up date. Where to begin? MG 7
B Windshield glass, where to buy Restoration & Tools 4
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
C MGA Where to tap into 12v for a power outlet MG 2
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
C Anyone know where to get one of these? Austin Healey 6
P Area where pillar, shroud, and drainage channel meet. Austin Healey 3
P Drainage Channel Where It Meets The Shroud Austin Healey 6
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
PAUL161 T-Series Where My TF Came From MG 1
