Tie Rod - Engine: What is it and where does it go?
blueskies
I'm back at the 100-6, assembling accessories onto the engine block and transmission in preparation for installing these parts into the chassis.
Moss catalog under Gearbox Mountings, has part no. 807-100, described as Tie Rod, Engine. I have a few of these in the pile of parts but have no idea where they go or what they do. Can someone help me out with this?
Also, a question about the push rod length for the slave cylinder. I bought a new slave cylinder and push rod from Moss, supposedly correct for this car. The push rod is about 1/2" shorter than several old ones in the parts pile. Wondering if this will have to come apart again when I find that the clutch does not engage?? Or maybe the Moss innards in the slave cylinder require the shorter push rod?? Here's hoping.
Healey Nut
The tie rod goes on the bottom of the gearbox/OD and connects to the bracket welded to the X piece in the chassis . It has rubber bushings and works together with the gearbox mounts and rebound rubber to keep everything stable under the torque of the engine .
Healey Nut
Pictures speak a thousand words . Tie rod bottom left .
B
blueskies
Thanks, Healey Nut. That makes sense. Now I need to order a couple of bushings for the tie rod and the two transmission mounts for the rear of the transmission. Don't know how I missed them in the parts order. I wonder if anyone in Canada has them?
Healey Nut
Autofarm has all that stuff .
HealeyRick
More precisely, the tie rod prevents fore and aft movement so when your motor and tranny mounts get all soft and squishy from all the oil sprayed on them over the years and you come to a panic stop, the fan doesn't plow into the radiator chewing it to shreds. :jester:
Keoke
Rick "U" Wanna BET----:highly_amused:
Reply Reply With Quote Blog this Post Contribute
John Turney
I replaced my tie rod bushings with the urethane ones used for the anti-sway bar. They're not so affected by oil.
B
blueskies
Thanks guys. How about part two of my original question, regarding the slave cylinder rod length? Any thoughts about that?
Those are the coolest jamb nuts I've ever seen.
I have this thing for flanged hardware, even better if the undersides are serrated!
The tie rod in my picture (the one on my car) was repaired, in that I welded a piece of 3/8 x 18 (NC) all-thread on to replace the damaged 3/8 x 24 (NF). While I do have some B-9 all-thread on hand (hardened 3/8 x 24) I didn't have the flanged nuts to go with it.
The thin washer between the pairs of jamb nuts is an internal 10-point star lock washer; I'm pretty confident my original settings on that will remain intact, though I suppose it wouldn't hurt to check on the condition of the bushings from time to time ;)
BMW uses LOTS of really nice hardware on their cars, if you can use Metric sizes; lots of bolts and nuts available with flanges, captive washers, copper-plated and crimped locknuts. Amazingly enough, their hardware__amoratized over millions of cars__is really pretty inexpensive, providing you find a dealer selling at true list price (or discounted). Thinks like Inconel bolts for exhaust flanges on the other hand, can be spendy! In part because I keep a large assortment of new hardware on hand (let alone saved bolts and nuts off the cars, tumbled & oiled) I tend to use BMW hardware for all kinds of shop & house projects too.
K TR2/3/3A Removal of tie rod end? Triumph 7
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 1
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
Feathers 289I inner tie rod end. TVR 0
S TR4/4A Tie rod end rubber replacement Triumph 6
S TR4/4A Tie rod end rubber replacement Triumph 1
D TR4/4A inner tie rod ball joint tension Triumph 0
Jim_Gruber Suspension Reinstall / Fitting Steerig Arm to Tie Rod End Spridgets 15
steveg Tie Rod boots - urethane Austin Healey 22
W Inner Tie Rod Spridgets 3
A TR4/4A Short or long tie rod end levers on TR4a Triumph 6
D TR6 Tie-rod problem Triumph 4
M Tie rod end came apart easy - too easy? Spridgets 6
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
DornTRoriginal TR2/3/3A Tie Rod Adjustment Triumph 6
Sopwith_Camel Tie rod ends Spridgets 12
P Tightening Tie Rod Ends? Spridgets 4
H TR4/4A Tie Rod In Door - TR4 Triumph 5
A MGB tie rod ends in A-H? Austin Healey 1
W tie rod replacement Triumph 4
Boink Tie-rod ends... types Spridgets 7
gbtr6 TR6 Question on TR6 trunnions and inner tie rod ends Triumph 6
Willie_P TR4/4A tr4 tie rod end/ball joint - technical question Triumph 2
R TR4/4A 1966 TR4a , outer tie rod question Triumph 7
Stinger TR4/4A TR4A Inner Tie Rod and Ball Joint Triumph 8
M TR2/3/3A TR3 tie rod ends Triumph 6
G Separate pitman arm from center tie rod Triumph 4
mjobrien Dimensions for Tie Rod and Cross Bar for 100 Austin Healey 6
eschneider Spitfire source for spitfire tie rod end boots Triumph 17
Tabcon Tie rod ends and balljoints? Racing 3
19_again GT6 gt6 tie rod lever Triumph 2
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
A TR4/4A TR4A rack / inner tie rod adjustment. Triumph 11
S tie rod end boots Triumph 23
drooartz Loosening the tie rod jamb nut Spridgets 12
KVH Ball Joint and Tie Rod Grease Zerc Fittings Triumph 4
Cottontop Tie Rod Ends Austin Healey 0
ArkleyOkie Tie rod ends Spridgets 5
19_again Tie rod lever threaded? Triumph 5
floyd TR6 tr6 tie rod end stuck...... Triumph 20
J Failed State inspection-tie rod end..follow up Spridgets 4
J Failed State inspection-tie-rod end? Need help Spridgets 8
T Inner tie rod ends Triumph 5
