What's the stock steel wheel size '64 Sprite?
Hagar
G'day all,
Like the title says. Are standard steel MkII Sprite wheels 13x4 or 13xSomething else?
Thanks
Taz
My Mk II rims are 13 x 3 1/2 bead to bead. Maybe 13 x 4 to the outside edge. Rostyle rims are 13 x 4 1/2 bead to bead.
jlaird
Think you will find that Bugeye, MK I and II are all 4 inchs wide. The rest is unknown to me.
leecreek
3.5 inside bead
T stock earlier style steel wheels MG 11
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
D Stock oil filter vs spin on filter Austin Healey 17
R Planing my built. Stock vs transplant Spridgets 58
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T stock bugeye front springs Spridgets 4
T Milling a head on a Stock 1275 for compression? Spridgets 13
