Trunk
jpr28056
Any tips on how to get in the trunk of a 79 MGB. The key goes in the lock cylinder and turns it but then when the button is pushed nothing happens. Maybe someone has a trick or an alternative means of getting in.
martyc
John Twist from university motors has a video on youtube that shows how to open the boot from the reverse lens using a long metal rod shaped appropriately. He's not successful in the video, but insists it works. Not sure if it will help, but I hope it does. Good luck! Others will probably have better advice!
Steve_S
Push down hard on the trunk lid while you press the button, then yank up. Sometimes you have to wiggle the lid around as you push. If that fails, you can drill out the tumbler and replace it once the latch has been properly adjusted.
Scott_Hower
Got speakers in your rear bulkhead?
tony barnhill
Great Pumpkin - R.I.P
Can't decide which I like the best but think its the "theft recovery model"
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Twit TR4/4A TR4 trunk badge Triumph 8
69MGC MGC Putting a 12v battery in the trunk MG 10
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
aero3113 100-4 trunk liner kit Austin Healey 4
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
JimLaney Refurbishing the trunk lid Spridgets 2
R TR2/3/3A Trunk floor replacment Triumph 4
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
S TR2/3/3A tr3 trunk primer Triumph 2
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
S TR4/4A trunk seal question Triumph 10
S TR2/3/3A T handle trunk lock Triumph 14
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
aero3113 Trunk Prop Stay Austin Healey 8
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
MisterB And now.... the trunk Austin Healey 12
maxwedge5281 bn6 two seater trunk Austin Healey 16
bcbennett Wedge Bonnet and trunk prop rods Triumph 0
M TR2/3/3A Water in Trunk Triumph 10
69MGC MGC MGC Trunk Thingies? MG 5
Rob Glasgow Armacord Trunk Liner Austin Healey 8
S Trunk Lid Spridgets 26
T TR4/4A Trunk lid lettering - template wanted Triumph 0
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
petnatcar Trunk modification for bt7 Austin Healey 15
magman BN-1 trunk latch adjustment Austin Healey 1
Scotsman TR4/4A TR4a trunk lid Triumph 2
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
S TR4/4A door and trunk seals Triumph 3
TRMark TR4/4A Trunk lid and handle assembly Triumph 7
B Gaskets for Trunk Lid Hinges Austin Healey 9
J TR4/4A Trunk Lid Seal Triumph 4
B Works Boot Rack [ For boot read trunk] Austin Healey 5
John Turney Trunk Lid Control Cable Austin Healey 2
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
M TR4/4A Trunk/Boot rubber seal. Triumph 8
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
M TR4/4A Cover for trunk/boot spare wheel....help please. Triumph 9
S TR2/3/3A trunk/spare tire Triumph 9
