TR6 TR6 Restoration Progress - My Car In The Shop
DanNagy
I have this car in a shop being restored, and would like to share its progress with you. After two years of planning, I am very excited that it is in its final stages and looking forward to seeing it when I return from Korea next week.
The first picture is of the transmission, the last thing that wasn't rebuilt. I had a J-Type overdrive unit added to it from John Esposito at Quantum Mechanics in CT. John was an awesome help, patient, and accommodating. I highly recommend John.
The second is a picture of the body from the front. The shop put on all new fenders and rear deck, primed it with epoxy primer, then sprayed it with the carmine red. He left the underside of the bonnet untouched so that there would be something original on the car.
The last picture is of the first badge going on the car. I think this should be a proud moment for Sports Car Haven (www.sports-car-haven.com)as the shop has been working months on it. Lorne Fritz is legendary for his craftsmanship in that part of PA, and I am so lucky to have heard about his shop through word-of-mouth. He is the best I have ever met, and a really nice, honest guy cut from the old mould that made America great.
It's going to be difficult to wait for it to be done, but then to leave it in storage will be worse. My next move/assignment is to Switzerland at the end of November, but I will have it when I return to PA for visits. I can't wait to contribute a shot to the "through my windshield" string!
roofman
Good luck with the completion.
jobster
From what I can see, it looks stunning. Bet you can't wait for it to get it put back together and drive it. The paintwork looks fantastic!
DanNagy
DanNagy
Thanks Paul. I can tell you that I am jumping out of my skin to get it back. I'll get the dizzy sent out to Jeff on Friday for its Petronix. I can't wait to drive it, especially after having the tranny rebuilt, the ignition fine tuned, and the car aligned. It's great to have the body work done, but its how it works that I enjoy the most.
2wrench
Very, Very nice. I've often wondered what it would be
like to drive a Triumph with an overdrive. Just
curious about if it still has power in that last
gear or if it kind of fizzles.
AngliaGT
It sounds like you need someone to take it out
& drive it every once in awhile for you.
I'll step up & volunteer.
Nice car!
- Doug
LastDeadLast
2wrench,
An overdrive is just like having a 5 speed manual... except that in the case of a J-type, you have 1st, 2nd, 3rd, 3rd overdrive, 4th, 4th overdrive.
So the answer is yes, you will loose power, just like you would with any 5 speed gearbox.
LastDeadLast
Just like I said... it's exactly like shifting into 5th gear with a 5 speed transmission... So, in your in forth gear at say 3000 rpm and click on the overdrive, you'll probably kick down to 2200ish (assuming a 28% reduction). The change in RPM would result in you being lower in the power band. But if you had the power to increase your speed back up to 3000 rpm then you'd be making the same power, but then I'm sure that wind resistance would start to come in to play.
Same principle with going into 3rd gear overdrive, except with lower speeds, but you would be less affected by wind resistance.
DanNagy
DanNagy
Thanks for the compliments, and cudos to the shop for their excellent work.
I wonder about driving with the overdrive, too. It's essentially a six-speed transmission now. I really struggled about putting it in because I found the 4-speed to be adequate in every way - even at highway speeds. In the end, I will make long trips with this car and wanted to give it a longer cruising capability. (And yes, this car is going to be a driver - not a trailer queen. In another 30 years somebody else can do another restoration.)
Will I be able to shift from 3rd overdrive to 4th overdrive directly, or does the overdrive kick out when you shift gears? I need a lesson.
LastDeadLast
DanNagy said:
Will I be able to shift fromm 3rd overdrive to 4th over drive directly, or does the overdrive kick out when you shift gears? I need a lesson.
Yes you can do this... what's a little embarrassing is when I forget to shift out of OD when I stop at a traffic light. When start out and get to third gear, it kicks back into OD.. which sounds just like shifting into the wrong gear.
Brooklands
Nice car!
Actually, I will be much closer if you need someone to care for the car when you are away. I can even keep it here in Allentown and garage if for you over the summer. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
DanNagy
DanNagy
Nice car!
The selflessness in the forum abounds. I am sorry to say that the TR6 has a home already, but we would love to visit!
nichola TR6 1973 TR6 Restoration - it’s a roller again! Triumph 4
B TR6 TR6 Painting/Restoration Triumph 2
K TR6 TR6 Restoration on Velocity Channel Triumph 6
M TR6 Video Up-date on my TR6 Restoration Triumph 1
I TR6 TR6 aluminum ring restoration help Triumph 6
G TR6 72 TR6 restoration Triumph 12
R TR6 '71 TR6 Windscreen Restoration Triumph 1
R TR6 Tr6 Winshield Frame Restoration Triumph 7
R TR6 Which Tr6 repair and restoration manuals to buy? Triumph 14
I TR6 Tinster's TR6 front suspension restoration part 1? Triumph 7
MTribe TR6 LIGHT restoration of TR6 floors and chassis? Triumph 9
Brosky TR6 TR6 Gauge Restoration may become easier Triumph 25
SCguy TR6 TR6 Restoration Stickers Triumph 5
G TR6 Rotisserie for a TR6 restoration project Triumph 12
bash TR6 Reality of TR6 restoration? Triumph 21
SCguy TR6 TR6 restoration $$$ Problems long Triumph 30
BierRunner TR6 TR6 Gas Pedal Triumph 1
nichola TR6 Another TR6 back on the road Triumph 1
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
E TR6 74 TR6 - “ A Post Seal” Triumph 0
J Wanted TR6 seat vinyl Triumph Classifieds 1
E TR6 Temp Gauge - 74 TR6 Triumph 11
K TR6 tr6 not starting Triumph 8
E TR6 74 TR6 Renegade Dash Wire Triumph 7
BwanaJoe TR6 TR6 radiators Triumph 4
E TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
M TR6 Fuse box wiring mystery Triumph 9
M TR6 Windshield Trim TR6 Triumph 14
J TR6 72 TR6 starter problem Triumph 10
nichola TR6 Procar Pro-90 Seats in the TR6 Triumph 0
E TR6 TR6 top dash trim paint Triumph 2
S TR6 Should I Buy This "73 Triumph TR6" Triumph 3
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
F For Sale Wheel Trim Rings Triumph TR6, $95.00 Triumph Classifieds 0
P TR6 TR6 Frame Stiffener Triumph 4
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 14
C TR6 Latest TR6 updates and pics Triumph 10
P TR6 TR6 Horn Relay Problems Triumph 8
tr6nitjulius General TR TR6 Triumph 0
Sherlock Triumph TR6 (rather modified) Spotted 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 0
M For sale rear wings Tr6 Triumph Classifieds 3
tr6nitjulius TR6 Ongoing Love Affair with 1 TR6 Triumph 8
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
M Have a pair of tr6 rear wings Triumph Classifieds 0
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale- TR6 Wiring Harness Triumph Classifieds 0
B TR6 TR6 1976 Clutch Choice Question Triumph 3
Gliderman8 TR6 Spark plugs for TR6 Triumph 7
