hondo402000
Ok, this weekend I purchased new battery cables, cleaned the starter connection and still starter acts sluggish at times and other times works like suppose to, so I decided to order a gear reduction starter from British starters, I hope he is reliable and the starter works ok. I also decided to put a main cut off switch on the pos side but didnt think about the other small wire attached directly to the battery pos terminal, so I think it would have been better to put the main cut off on the neg side, since when you are working on electrical stuff they always say disconnect the ground!! once the starter is installed I will let you know what I think
