TR4/4A TR4A Guages?
Mattryanmusic
So I have a 1967 TR4A, IRS. It had a V8 Swap done to it before I bought it. The only thing I had to do to it when I bought it is put new gauges(Speedo/Tach) in it since the originals won't work with the new engine/tranny. So I guess my question is, should I sell the original gauges and free up a little cash to do a few small other things the car needs like a new top? Or should I just hold on to them in case I end up selling the car and the new owner wants to restore the car back to factory? Some other factors to consider, The factory center console for the radio is missing, but I have the radio. So is the original engine/tranny.
Thanks for your response's, I know it's a bit long winded.
TR4nut
Sell em. Anyone buying your car later is going after the V8, and I doubt will care about the gauges. They won't add to the sale value of your car. Not sure your gauges will get you all the way to a top, though.
Randy
Geo Hahn
Gauges won't get you a top but that radio might -- those can go for silly money if they are typical 'original' equipment in good working order.
Are you saying the center console that would connect the dash to the floorboards is not in place? I don't think that thing was merely decorative or to just hold the radio, I believe it helped keep the scuttle shake down and make things more rigid when they went to the cardboard tunnel cover.
OTOH, with your engine swap perhaps you have a very different set-up in that area.
M
Mattryanmusic
Well, I know the gauges won't pay for a new top, but would lessen the sting. The center console I'm talking about is the one that connects the dash to the trans tunnel that holds the factory radio. My trans cover is made of steel and is riveted in, probably made to clear the C3 Transmission and provide a sturdy place to mount the B&M ratchet shifter. I think I'm just going to put the Speedo, Tach and the radio up for sale to fund my new top. I think Randy (TR4nut) is right. Having those extra pieces won't effect the resale on the car since most buyers will be more interested in a nice, clean, ready to drive car with a nasty little V8.
MichaelG
Marty,
Welcome to the list. I would sell the gauges. If you have the opportunity sometime, determine if you can make that the center console fit. It does provide some support for the dash, probably more to eliminate vibration and attendant noise. Mine was out for a while and I noticed a subtle difference when reinstalled. Why not post a picture when you have a moment?
Do you have the original engine?
Cheers
M
Mattryanmusic
Here's a shot of the interior. I don't have the center console or the original Engine/Trans.
martx-5
Very nice...but you're just teasing us with an interior shot...<span style='font-size: 12pt'>We want to see the engine bay!!</span>
M
Mattryanmusic
Here it is, I've since changed the Air cleaner to a chrome one and those nasty looking manifolds are getting replace with headers soon. I've also cleaned up a lot of the wiring to make it look neater.
TexasKnucklehead
That is very nice. I guess the battery is in the trunk. Can we see another picture of the other side of the engine bay? I'm wondering if the steering column had to be messed with. I'm guessing it runs a little better than the 4.
Welcome to the forum. You'll find that people here will not always agree with you, or what you might be doing, but they'll help you out just the same. Your conversion is something I'd never consider, but I bet it's a lot of fun to drive.
TR4nut
Actually, I'd like to take a peak at the brake mod too.
Randy
angelfj1
I realize that I am the perpetual <u>curmudgeon</u>, but I don't see the point. BUT I admire the engineering and hard work.
I am sorry but it's not a Triumph.
M
Mattryanmusic
I'll have to snap some more pics of the other side. The brake system has what appears to be an after market booster with the stock master cylinder. The pedal had an odd feel compared to modern brake systems that I'm used to, but has no problem stopping the car. The column hasn't been hacked to bad, but definitely been modified to clear the manifolds. It has a few small things here and there that I need to go thru and clean up, but it was still easier and cheaper to buy the car than building it myself. Heres the most current pics from last weekend.
G
The cool part is it looks totally stock from the outside. Bet you surprise a few modern sports cars when it comes time to push the giddyup pedal.
vivdownunder
Ah, the mighty Windsor....good enough for the AC Cobra 289 and Sunbeam Tiger, so it should really motivate the 4A.
There doesn't appear to be any splay on the rear wheels, so is the IRS still in, or has it a live axle?.
You will find the headers release extra horsepower, and improve economy. The trade off can be more heat in the engine bay and a noisier cabin, as I found when I recently fitted them to the 302W in my 66 Mustang Conv.
Here's a few more conversions....check out the 427 TR4 !.
https://www.britishv8.org/Photos-Triumph-Conversions.htm
Enjoy the burble !
Viv.
TR4nut
It does look like a nice sleeper. If its an IRS, and no ones told you yet, pay attention to those rear diff mounts..
Randy
amcboy
My .02 is that with some smallish effort you could use the original gauges.
Get a distributor for a Ford with a mechanical tach drive (not too uncommon).
And have an adaptor cable made for the speedometer. Possibly incorporating a ratio box.
Any competant speedo shop should be able to make one.
martx-5
There are gauge restoration places out there that will convert mechanical tachs to electric. Just another possibility for retaining the original style gauges.
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
RJS TR4/4A TR4A Seat Upholstery - Piping Question Triumph 7
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
RJS General TR TR4A Seat Rebuild Triumph 12
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
T TR4/4A Recommendation on top for a late TR4A Triumph 8
S TR4/4A Build Date Triumph TR4A IRS Triumph 3
R For Sale Tr4a parts Triumph Classifieds 2
Sarastro TR4/4A TR4A top's rear attachment Triumph 2
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
fpstude TR4/4A Steering U-Joint Question for TR4A Triumph 5
S For Sale Triumph TR4 and TR4A Factory Workshop Manual on CD/ROM - 1962 - 1968 Models Triumph Classifieds 0
G TR4/4A Vin # for TR4A Triumph 3
M TR4/4A Seats for TR4A Triumph 3
B TR4/4A TR3 valve cover on TR4A Triumph 4
T For Sale TR4A Grille Triumph Classifieds 0
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
K For Sale TR4A Grille with Embedded Fog Lights Triumph Classifieds 0
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
D Wanted TR4A Live axle frame Triumph Classifieds 0
D TR4/4A Tackling the biggest problem with my TR4A.... Frame Damage :[ Triumph 70
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
