KVH
No gas at the carbs, stalled going 50MPH.
I'm checking the fuel lines for obstruction at this time, but I note something strange. There's a bright stainless steel pivot pin sticking out of the fuel pump right about where the manual shows the fuel pump "cam arm" to be. If I'm not mistaken, the pump is probably coming apart from engine vibration, and the pin is just working its way out. The cam arm or "pump flipper" must be pushed right out of place and might be damaged.
I may need to remove the pump.
Is this a common issue with TR fuel pumps?
thx
thx
