Replaced original fuel pump ,(with primer lever) for an aftermarket pump w/o priming lever. Having trouble pressurising from outlet tube to fuel line and then on to the Carbs.
Put her away pretty dry , so I put a couple of gallons of gas in the tank before starting.
Maybe I need a little more in the tank to cover the sending unit? I'll be darned if I can put my finger on the problem.
At least the install went smoothly and fuel color in bowl and filter are nice and clear.
Any Thought's?
Thanx
Winston TR4A IRS
Going to a larger olive that will cover the exposed end of the outlet tube.
Any Thought's?
Thanx
Winston TR4A IRS
