TR2/3/3A TR 3A Tail Lamps
CJD
OK, another newby question:
What is the tail lamp configuration on the 3A? The license light is easy, but what is the function of the inner round and outer oval lights? Which are turn, marker, and stop?
Thanks,
John
Geo Hahn
And note that although the corner lights (brake & tail) are double filaments those filaments are not the same brightness.
You will want to wire them so the brake lights get the brighter (bigger) filamant. I can never remember which bottom post is which so I have to figure it out all over agian each time.
CJD
CJD
Thanks, I'll figure out which filament is which.
Oh, also, do the lamps ground thru the mounting screws? They have a connection for a ground wire, but I can't see that a ground wire was ever used.
They do ground thru the mounting screw, you want to do a grd wire, thats one of the biggest causes of the lights not working on a TR.
Marv
CJD
CJD
Finished up today. All the lights had the connector for a ground, but the connectors were never used. I grounded each light to the body individually, and then ran a ground wire connecting all the lights together. So now all five lights will remain grounded as long as a single light remains grounded. And, if I have odd issues with all 5 lights at the same time, then I'll know it's a ground...at least that's the plan!?!
Thanks all for the tips!
John
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
CinneaghTR TR4/4A Rechroming TR4 tail lamps? Triumph 10
ronzet Curious glowing on my Tail lamps MG 28
S TR2/3/3A Pinion tail bearing replacing Triumph 12
D TR2/3/3A 3D printed tail light Triumph 12
bigjones TR2/3/3A Rear tail light not budging Triumph 5
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
O Spitfire Tail lights not working Triumph 6
T Tail light extension Spridgets 2
drooartz MGB Early tail lights on later car MG 17
JFS Wedge Brake and Tail lights Triumph 3
R bugeye tail lights Spridgets 6
johnrip Wedge TR7 LED Tail lights from Wedge Shop Triumph 1
C MGA R/H tail lamp removal on a 1962 MG 5
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
N Wanted Early rear tail light lens Triumph Classifieds 0
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
S TR2/3/3A Aluminum tail pipe section Triumph 3
L TR2/3/3A Rear tail light cutouts Triumph 213
G For Sale Round-tail Spit-6 Project car with OD for Sale [Cambria CA] Triumph Classifieds 0
B Stop/Tail light wiring Austin Healey 23
Jim_Stevens For Sale Pair of chrome tail lamp bases, NIB, Moss 159300 Triumph Classifieds 0
RandyInUtah Wanted TR3 Original Tail light lens Triumph Classifieds 1
F TR2/3/3A Tail Lights Triumph 3
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
S TR2/3/3A outer sill and fan tail Triumph 11
K TR2/3/3A Ck Technologies tail light blinker? Triumph 3
T Auburn Boat-tail Speedster Spotted 3
M TR6 Tail Light sockets Triumph 1
M Tail light sockets FORUM Navigation Questions 1
M MGB Tail lights do not work- 1977 MG 8
M TR2/3/3A Tail pipe finisher [extension] Triumph 13
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
R Tail light wiring ??? Austin Healey 5
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
D Help! No tail lights or sidemarkers Jaguar 14
B Tail pipe chrome attachement to look nicey nice?? Spridgets 28
R smoke out of tail pipe Spridgets 46
C tail light Austin Healey 1
Got_All_4 Wedge TR7 tail light gasket Triumph 5
I LED tail light suggestions? Spridgets 22
Darrell_Walker tail light reflectors -- chrome or white? Triumph 7
Morris Deffective tail light assembly? Spridgets 6
bighealeysource LED tail lights for Healey's and most Brit cars Austin Healey 7
M TR2/3/3A TR3 Tail light question Triumph 4
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
S TR2/3/3A tail pipe tr3 Triumph 6
G No left tail light Spridgets 2
