Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
What is the tail lamp configuration on the 3A? The license light is easy, but what is the function of the inner round and outer oval lights? Which are turn, marker, and stop?
And note that although the corner lights (brake & tail) are double filaments those filaments are not the same brightness.
You will want to wire them so the brake lights get the brighter (bigger) filamant. I can never remember which bottom post is which so I have to figure it out all over agian each time.
Finished up today. All the lights had the connector for a ground, but the connectors were never used. I grounded each light to the body individually, and then ran a ground wire connecting all the lights together. So now all five lights will remain grounded as long as a single light remains grounded. And, if I have odd issues with all 5 lights at the same time, then I'll know it's a ground...at least that's the plan!?!
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
