MGB Time to replace my top,,experienced recommendations welcome
111
My 1980 MGB rear window became hazed over about a year ago, and recently dropped out of it's stitching. So I will need a replacement top. I see different ones in the $250 range on ebay, some with the zippered rear window like mine(even though I never once unzipped it), others without. So I need some recommendations as to which ones hold up the best is very hot and sunny weather.
Also a local shop that does convertible top installs said they charge between $350-$450 for the install. While the price of the top itself seems reasonable, the install price seems high to me. I think I paid around that price for a much larger one on an automatic top. Any thoughts/opinions?
Platinum
Look for a Robbins top. No matter the installer, the top and the rear window material will withstand Florida climate beyond ANY bargain counterfeit!
Been fitting Robbins tops to any and all drop-tops both personal and clients for at least forty years. They just ROCK.
...and I have NO financial interest with them.
bob67bgt
A good installer can do it in around 2 hours +/-. You can do it yourself with a bit more time and not rushing it. Try running with the window unzipped. Makes it much cooler in the summer heat. Bob
drooartz
Install is certainly something you can do yourself, but I'll admit I had my local upholstery shop do the one on my last MGB. Price you were quoted is similar to what I paid for mine.
Running with rear window unzipped was great on the hot days -- lots of air flow and shade.
Platinum
All ya need for the job:
Cuppa and a good cordless drill. :jester:
Along with a PopRivet gun, some chalk (for marking a centerline and the front edge rail alignment), the Tenax tools or a paper punch for installing the rear fasteners.
GaryBeu
Banned
AND...if you unzip the window when you put the top down it doesn't crinkle it so it lasts longer. Carla and I replaced ours in an afternoon with no prior experience. It was no problem and it looks good.
PAUL161
Prestige in the UK makes a nice top also. The mohair one, on our car, is very well made and because of it's thickness, quiets down some outside noise. Good people to work with. A little pricey, but excellent quality. PJ
WillR
I was able to do mine easy enough and I have never done anything like it. A big Healey on the other hand iv heard to take them in. They seem a lot more complicated. I enjoyed my zip out window. Try it out once in awhile.
111
Thanks for all the replies thus far, as they are very informative.
I am a handy person, but my time is limited, I am a perfectionist when it comes to me doing tasks, and as I get older, I seem less interested in doing projects on the cars. However if it is as easy as everyone is sounding, I might be willing to tackle it, especially if the going rate for install is $350+
It makes you wonder though why the price would be so high for what sounds like a relatively easy install?
trrdster2000
111, The price includes a replacement if they screw up. If the weather had not been nice today, I was going to say I would fly down and do it for you (sick of rain and ice). A round trip ticket from Charlotte would be cheaper for you, I think??
Wayne
daviddlong
If you do decide to do it yourself, one method to get it tight is with heat. Attach the rear portion as usual. Attach the front of the top to the front of the top frame with cloths pins or whatever. Then, close the windows and put an electric heater inside the car (I put it on the battery shelf with the seats folded forward) and let it run for 2-3 hours. The top will now be pliable. Attach the top to the front of the top frame with only mild to moderate tension. Finally, leave it alone for a fortnight. DO NOT PUT IT DOWN DURING THIS TIME BLOCK. It is still a fussy job. Good luck
drooartz New top -- what else to replace? MG 10
R 1275 vinyl top replace, step-by-step instruction? Spridgets 5
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
V MGB Replace late intake manifold angled breather with early model straight? MG 1
W replace rigid master cylinder lines with flex. Spridgets 2
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
B A plan to replace BE floor pans Spridgets 0
nichola TR6 Rebuilder or replace wiper switch? Triumph 7
R TR2/3/3A Replace wiring harness in steering column Triumph 61
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
K TR2/3/3A Time to replace the exhaust header wrap.... Triumph 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
J TR2/3/3A replace brake and fuel lines? Triumph 4
J TR2/3/3A Replace rusty sills? Triumph 10
NutmegCT Brake fluid - flush and replace. Why? Restoration & Tools 8
F Dynamo not charging [BT7] - replace brushes or buy new? Austin Healey 24
JPSmit replace shocks in pairs? Spridgets 7
JPSmit When do you replace things? Restoration & Tools 22
wangdango BN2 wheel cylinders/rebuild/replace? Austin Healey 3
AUSMHLY When to replace spark plugs Austin Healey 1
drooartz MGB What to replace when engine is out MG 10
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
AHS BJ8 blower motor switch - how to replace? Austin Healey 1
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 4
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
R TR2/3/3A Replace Upper Wishbone Ball Joint Triumph 15
TRMark TR4/4A Replace Water Curtain Triumph 5
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
John_Mc TR6 Rebuild or replace Clutch Master Cylinder? Triumph 8
S Replace original suspension for shocks? Austin Healey 2
J Replace the outside skin on a cargo trailer??? Restoration & Tools 0
drooartz MGB Good people go to heaven, bad people replace MGB clutch hydraulics MG 2
7 How to replace door windows on a 77 MG Midget Spridgets 6
AngliaGT '74 Midget - Best way to Replace Brake Line? Spridgets 1
S Replace seal and dust cap BJ8 steering box. Austin Healey 23
gbtr6 TR6 TR 6 Head Studs, replace? Triumph 3
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
B Radiator - repair or replace? Pics attached Austin Healey 20
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
mailbox General Tech Fix, replace or rewire? Triumph 8
Kleykamp TR2/3/3A '61 TR3 Horns repair vs replace Triumph 15
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
britlover proper tire size to replace 5.90-15? Austin Healey 16
Rob Glasgow Replace clutch disk? Austin Healey 8
S TR4/4A Replace or rebuild heater control valve? Triumph 5
