Throttle cable
TR3driver
Great Pumpkin - R.I.P
FWIW, I had a lot of trouble with reproduction throttle cables not lasting on my Stag. So I ducked into the nearest bicycle shop and picked up their longest "teflon lined" brake cable. Worked out very well, and cost about 1/4 what I'd been paying for the repros.
DNK
Mike, I was going to post what Randall said when you posted on Woody's forum. There are a few who have gone that route.
Thought I'd wait and see if Clint could dig something up first,but Randall took care of that.
M
mlapage
Thanks to all of you for your suggestions. There are not many available in the marketplace.
swift6,
I did find a cable at Wedge Parts ($35).
TR3driver,
The use of a bicycle brake line is an interesting idea.
Thanks again
DanB
Last summer the new VB cable I had installed broke..not their fault..., so I went to Wal-Mart and got a set of bicycle handbrake repair cables. There were 2 of the 4 in the pack that were long enough, and I am still using the first one.
Dan B
DNK
Did you talk to Brad to make sure he has one? He is just restarting his Business after being away from it for away
M
mlapage
I have an email in to Brad and had a short discussion with Woody the other night about the rarity of TR8 accel. cables.
I have my car in a shop, in Austin, TX and the mgr. said he had a fix on an original for $150. His mechanic has the old cable working and I will drive my car (keeping fingers crossed) until I find a one I can afford.
Still on the hunt.
Thanks again to all.
3798j
Bronze
If I had a nickel....for every sale made of stainless steel brake cable with teflon lined housing that was used for everything and anything other than a bicycle's caliper brake, I'd have alot of nickels. There was one guy in particular whose restorations of big Healey's were wonderful. His business card read something like "Bob's Toys For Big Boys". The guy was good.
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
Walter74 Throttle Cable Conversion Austin Healey 6
T Philosophizing on keeping cars for more decades - prompted by a broken throttle cable Spridgets 3
P Bj8 rhd cable throttle conversion - help Austin Healey 6
TomMull Shortening a throttle cable Q&D with stuff in the shop. Restoration & Tools 5
MY66AH Throttle Cable Issues Spridgets 12
J TR2/3/3A Throttle cable instead of the linkage?? Triumph 1
B Weber DGV Throttle Cable MG 2
W HIF44 carb... throttle cable connection Spridgets 9
G 1500 dual SU/ DCOE throttle cable question Spridgets 5
smaceng BE Throttle cable length? Spridgets 4
Brosky Anatomy of a Murder [of a throttle cable] Triumph 8
H Throttle cable and choke cable holder MG 3
58Custom Who makes the best throttle cable? Spridgets 9
J Healey 3000 - throttle linkage [cable] Austin Healey 11
S MGC MGC Throttle "Kick Down" Cable MG 5
philman Wedge TR8 Throttle Cable linkage help Triumph 3
Darrell_Walker Racto throttle cable routing Triumph 28
Steve1970 Effect on throttle plate when pulling choke cable Triumph 2
Luke_Healey Throttle cable brass piece stuck in cable stop. Spridgets 7
Brosky Ratco throttle cable installation Triumph 2
Ab Crevoiserat TR5/TR250 Throttle Cable for TR250 's and 6's Triumph 18
Lin Carb Linkage and Throttle Cable Austin Healey 3
Lin throttle linkage/cable Austin Healey 3
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
Popeye TR4/4A Throttle Linkage Triumph 5
CARSINC Throttle linkage question Spridgets 1
S Overdrive Throttle Switch Austin Healey 4
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
rgfrey 1959 BN7 Throttle Control Linkage Austin Healey 2
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 31
J Throttle Controls Identification Austin Healey 4
B RHD BJ8 Throttle Control Rods Austin Healey 9
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
C Jammed Throttle Linkage Austin Healey 3
R TR2/3/3A Throttle rod spring location Triumph 3
T BT7 throttle relay levers short and long Austin Healey 2
R TR2/3/3A Carb throttle return spring tension Triumph 2
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
D TR4/4A SU HS6 throttle spindle size Triumph 20
F TR2/3/3A Throttle linkage cross rod Triumph 4
C TR6 Carburetor Throttle Linkage Triumph 10
warwick-steve Throttle shaft bearing/bush on bulkhead Austin Healey 9
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Lukens TR2/3/3A Installing a throttle. Triumph 2
