Stuck Trunk Lid
Smesne
Or should I use the term "boot"?
Either way, I cannot get the trunk release to work, no matter how hard I pull on the release handle. My brother was able to cut the carpet in the spare tire cutout (the spare is not in the trunk), but could not see how to get the latch to release.
I just purchased this car for a restoration project and have not even really begun to work on it, but I'm going to need to get in the trunk eventually.
Any suggestions?
ronzet
I have had this problem once in a while on my A..
Comes from the rubber seal sticking to the lid...
I have an old bottle opener that has one of the ends looking like a straight slot screw driver that has been bent to 90degrees....
I very gently put the 'hook' under the trunk seam near the latch and pull up <span style="font-style: italic"><span style="text-decoration: underline"><span style="font-weight: bold">gently</span></span></span> while some else pulls on the latch handle...
Unless there is a problem with the latch itself.. this should work...
Smesne
Smesne
Sorry guys, yes it is a '57 MGA. The car is a basket case I bought to restore. There doesn't actually seem to be any rubber left, so I'm leaning toward a problem with the latch. It appears that the release lever doesn't move far enough to allow the latch to completely disengage.
Fortunately, the spare is not in the trunk so I can get to it from the passenger compartment with some contortions.
Worst case is that I have to undo the hinges which I'll need to do eventually.
Thanks.
Smesne
Smesne
I was able to undo the hinges and wiggle the lid to the side freeing the latch. It turns out a few shots of PB Blaster loosened up the latch enough for it to start working.
There wasn't a speck of rubber left around the trunk, but I was pleasantly surprised to find the trunk floor to be completely solid.
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
Boggsy64 MGB Truly stuck now MG 10
T TR2/3/3A Stator tube, wires stuck Triumph 15
