Boggsy64
Engine mounts! The plan is simple jack up car, jack stands, loosen mount bolts, jack up motor, replace mounts, put back together... Simple right?
OK now the quandary, puzzle, conundrum, situation. I will not go into the difficulties of getting the old mounts out. The 1977 has two parts a steel bracket on the motor and a "hockey puck" rubber mount. This is different than the older models. So I have the right, passenger, side mount in and cannot get the motor to raise up enough to get the left, driver side, in. As I jack it up, at a certain point the whole car starts to raise. I cannot see what is causing this, and it must be in the tunnel, transmission?
The problem is the rubber "hockey puck" mount, with built in stud, is 1.5" wide and the gap it goes in is 1" wide. I cannot get the gap to open enough to get the mount in. I have tried everything short of cutting out the frame, obviously not an option. This is one place to not have a stud, but a nut within the mount, I just need a 1/2" and this is killing me. If I take the passenger side mount off I can get the drive side in, but then cannot get the pass side in.. Doesn't appear possible to get both in.
I bow to whoever has figured this out and appreciate any suggestions ,other than pull the engine out? By the way this car was obviously in a collision in the past... Don't know if the frame is bent causing the lack of space....?
