TR2/3/3A Oil drain plug stuck
joshsibille
I've been breaking down my engine ('61 TR3A)to pull it, but for the life of me, I can't get the oil drain plug out. I've soaked it with PB blaster, tried a breaker bar, even to some extent an impact wrench with a universal joint(only way I could get it to reach). Anybody have any thoughts as to how to to get the d*** thing out? Would like to drain the engine before pulling it, but its looking like it may have to come out full of oil then get taken out when its in the open. Any thoughts would be greatly appreciated.
STeve 1958
My first impulse was to say " Righty righty, lefty loose " but that would be cruel.
You might try heat. use a 1200 degree heat gun, not a torch. Then a breaker bar.
Someone must have thought they could stop an oil leak if they got it tight enough.
NutmegCT
I had a similar experience on an old Jaguar saloon. My dad taught me something a zillion years ago: put a wrench on the bolt head, but lightly tap the wrench with a hammer *the direction you'd normally tighten it."
That light "backwards" tapping usually breaks the bolt out of the rust or whatever is holding it, so you can then turn it normally to loosen it.
Not always - but worked for me many many times on various cars.
Tom M.
TomMull
Put a breaker bar with a 3 foot pipe "cheater" on it. If that doesn't do it, increase the length of the cheater. Oh, and you can tap it too.
Tom
TR3driver
Great Pumpkin - R.I.P
This puzzles me; I've never had any trouble at all twisting off those dang pipe plugs without using a cheater bar at all. Seems like they're made of stale cheese that has gone soft again (no doubt from exposure to hot oil).
IMO, if an 8 point socket and breaker bar doesn't get it, it's time to start drilling for oil.
Some teflon pipe dope on the replacement will help ensure it doesn't happen again.
Tom
sp53
The bolt is probably shot by now and I am wondering if it a square plug or a bolt someone put in its place. I actually think the treads in the pan are angle pipe treads. Sometimes a good bite with vise grips and a 4 to 6 pound hammer to bump it with lets the mass of the big hammer do the work, but again vise grips can backfire and take all the sides off. I have had to weld a nut on what was left of plug before and the heat from the welder and a new clean nut it made it so popped right off.
Welding the nut was a lot easier than I thought it would be and I had wished I had done it sooner.
CJD
In the short term: "Give me a lever long enough and a fulcrum on which to place it, and I shall move the world." (Archemedes 250BC).
In the Long term: Don't let anyone else touch your ride!
TR3driver
The later pans were pipe threads, the factory used common square head pipe plugs. (Which I like to replace with hex socket plugs.)
Tr2 and early TR3 took a different, hex head plug with straight threads. I don't recall the thread offhand, but I believe it was SAE. There should be a fiber sealing washer, too.
The pans are interchangeable, of course, so its never quite certain what you will find on any given car. But the pipe threads are much more common, just because they made so many (same pan for TR4 and 4A as well).
titanic
Amended version: "Give me a lever long enough and a fulcrum on which to place it, and I shall break anything and/or maim myself." (Berry 2019 AD)
Berry
B TR4/4A Oil Drain plug size Triumph 14
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
Marla TR4/4A Oil Drain Plug Triumph 4
KVH Leak at Oil Drain Plug Triumph 12
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
L What size and thread pitch oil drain plug? Spridgets 5
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
Stewart Leaky transmission oil drain plug MG 3
RandallRK Differential oil drain plug Austin Healey 13
H Where is the Overdrive Oil Drain Plug and Filter? Austin Healey 2
RSMTR8 Wedge TR8 Oil Drain Plug Triumph 1
78MGB Oil Drain Plug Washer *DELETED* *DELETED* MG 3
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
J Toyota tranny conversion question, oil drain hole Austin Healey 1
tahoe healey trans oil drain Austin Healey 11
kindofblue Which Tool for the Oil Drain Bolt? Triumph 9
tahoe healey oil drain plugs Austin Healey 11
K TR2/3/3A Oil pressure at Hot idle? Triumph 3
O TR6 Oil filter relocate kit Triumph 8
S TR6 Oil Pressure Light Triumph 2
Lin Oil sump sealant question Spridgets 0
H 280i oil filter TVR 2
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
Geo Hahn TR6 TR6 Oil Line Thread Size Triumph 1
R Oil Filter Removal Austin Healey 1
Lin Oil sump torque value? Spridgets 3
K TR2/3/3A Adding STP to Castrol 20W50 oil? Triumph 5
L BMC A-series: Oil in coolant British Motor Corp 6
A T-Series MGTD oil pump bypass valve MG 0
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
M Oil Pump for BN2 Austin Healey 4
tr6nitjulius Oil flow view inside operating engine Other Cars 4
R TR2/3/3A Oil Leaks Triumph 24
tahoe healey Gold Sparkle in Oil Austin Healey 15
Got_All_4 TR6 Oil in the coolant in my TR250 Triumph 6
J TR4/4A Oil Deflector Triumph 4
A T-Series Mgtd oil pump alterations MG 2
S Add ZDDP to gearbox oil? Austin Healey 29
E MGB SU CARB OIL 1965 mgb MG 3
Kurtis No oil pressure Spridgets 5
E Oil leaking from the Tachometer cable Austin Healey 5
Walter74 Oil sump AH spares Austin Healey 5
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Basil Neat trick for reading oil level Restoration & Tools 7
T Spin-On Oil Filter Removal [BJ7] Austin Healey 12
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
nichola TR6 Oil pump drive barely engages Triumph 2
C TR2/3/3A Right oil Triumph 8
Lin Gearbox Oil Austin Healey 4
E TR6 Transmission Oil Seal Triumph 13
