Stuck Thermostat Housing ......
George Zeck
I am overheating and have been advised to change the thermostat on my 1100 Sprite engine. Drained the coolant (of course broke the draincock, had to use lower hose) and removed 3 bolts holding the thermostat housing in place. From my overly generic book -- I sho /ubbthreads/images/graemlins/thirsty.gifuld just remove the house and swap out.
Wrong !! I've pryed -- hit -- wedged in attempt to split the housing from the bottom with no avail. No other bolts appear to be related. Soaking w/ PB Blaster (nut / rust loosener).
Am I missing something ? Could I've heated the thermo to "melt" the two peices together ??? Any and all help appreciated. /ubbthreads/images/graemlins/thirsty.gif
Biff
George, 9 times out of 10 it's the studs holding the housing. Double nut the thermostat housing studs and torque them completely out. Then you should be able to knock/wedge/lever it off. Soaking the studs before removing them will make it easier. When re-installing the housing use some S/S bolts in place of the studs and it will make future changes a whole lot easier.
Geo Hahn
Not melted together but more like glued by some sealant such as Permatex. That brown stuff can set up pretty hard. Soaking with a solvent may be the answer but not sure that PB Blaster will help (depends what has been used in there). Carb cleaner or Acetone are possible solvents but should be used carefully as they are also rough on skin, rubber, paint, etc.
Do you really know that you need to change the tstat? There are lots of other (more common) causes of overheating. You don't need x-ray vision to know if your tstat is opening -- you can feel the lower radiator hose suddenly go from warm to hot when coolant begins flowing thru the radiator.
George Zeck
George Zeck
Problem solved. Prev owner used a silicon type item to "solve a problem" ( & created more). Got apart w/ patience and a strudy paint scraper to wedge into a tighten spot than the screw driver would allow.
Crosion City -- needs replaced !!
Thanks !!
Geo
RJS Thermostat Stuck Open? Triumph 11
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
R stuck valve Austin Healey 14
C Overdrive stuck Austin Healey 10
T TR4/4A Geez - this head is really stuck on the engine Triumph 6
B stuck in 4th gear bj8 Austin Healey 8
jfarris TR2/3/3A Reverse shift rod stuck Triumph 7
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
C TR6 ZS 175 CD2 stuck air valve/piston Triumph 5
Rut Stuck fasteners Spridgets 1
T General Tech Brake caliper - piston stuck Triumph 4
trotti Stuck drum - any ideas? Austin Healey 5
KVH General Tech Removing Stuck Head Studs from Block Triumph 18
bugedd Looks like you guys are stuck with me Spridgets 10
K TR2/3/3A Help!..Installed new Clutch....Trans stuck in Gear? Triumph 8
J Rear spring front pin stuck Austin Healey 8
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
T TR2/3/3A caliper piston stuck Triumph 12
M 99 L/H Drive X308 Hood latch Stuck Jaguar 0
richberman e-brake stuck on Austin Healey 36
Boggsy64 MGB Truly stuck now MG 10
