I am still going through Awakening a Sleeping B so the car is not running yet, but want to start this thread so I have some info ready for when I get to the clutch part of it.
First I checked the fluid level and clarity of the fluid. Level was OK and so was the clarity.
I noticed that the clutch pedal was real soft at first (non running car) and as I pump it it started to get harder. Then as it got harder it did not want to return to the up position but kind of slowly returned.
I had a friend pump the clutch pedal as I looked into the master cylinder resevior and noticed that it started to fill up and turned an awful shade of murky muddy brown.
What can this initially tell me about the condition of the clutch? I am working at getting it started and should have it running by the weekend. The clutch will be next in line. The car has 79,000 documented miles and the car was never abused so I think it might be off somehow from sitting.
I am also asking this question for another reason. If the clutch disc is stuck, will it effect me being able to turn the engine over by hand thereby making it tough to adjust the valves? https://www.britishcarforum.com/ubbthread...p;page=0#196976
