Have been reading a lot in several places about setting the timing for the MGB at 32 degrees @ 4000 rpm with vacuum disconnected. How do you read 32 degrees? Do you use a timing light with a advance knob set at 32 degrees and then line up with TDC, or what. Any help would be greatly appreciated as I'm not exactly sure about the timing on my recently rebuilt engine.
