philman
OK, trying to remove head from my spare tr7 engine. I can see light between the head and block but cannot lift the head from the block. I tried the rope trick (using a 6 ft breaker bar to apply force to crank shaft), no good. tried lifting head with block attached and pounding on the cast iron block. Any other ideas? Do I have to remove the studs? The block is otherwise stripped down.
My spare engine is a FI engine. I thought that since there is no smog adapters on the head it would be a better head to modify for higher (?) performance for my '76 fhc (which currently has #1 sparkie wallowed out by previous owner and won't hold an insert).
