rear shocks for a xj40/
Sprocket
Member
I have a 1990 Vanden Plas Majestic that came from the factory with the self leveling shocks. When my father purchased the car (2nd owner) he had some issues and had the set swapped out for the standard bits by the Jaguar dealership. That was prbably about 6 or 7 years ago. The car is driven only a few thousand miles a year and here we are roughly 15-20K later and the rear shocks are shot. I push on the the back of the car and it bounces about 3 times and I can hear the shocks bottoming out (clunk clunk on every little bump in the road).
Looking online I see a variety of shocks in many price ranges.
Wondering what the best price vs ride quality shock to consider is. High performance shocks are not needed for the car.
The car is driven by my mother mostly on surface streets with little highway miles. Namely a grocery getter.
Thanks in advance.
Exotexs
generic shocks are just as bad as those that you pay an arm and a leg for. So spend the least and you won't be dissapointed. Monroe, Gabriel, they'll do the job just like expensive shocks, and who knows, they might last you longer!
Ride quality: the Jaguar is a soft riding car, so go for a medium-soft shock. I'm probably younger than your mother and I still prefer a soft ride, no back-breaking Konis for me. Remember Consumer Reports' 1990's study about flashlight batteries? They concluded: "buy the cheapest, the cheapest batteries outlasted the expensive ones". The same logic can be applied to shock absorbers.
I've used Boge, Koni, Bilstein, Gabriel, Monroe, Girling, and others. The only shock I haven't tried is SPAX and I understand they are v e r y good shocks, but expensive.
My favorite were the XJ-6 factory Girlings, but Girling no longer exists. Then I installed Boge and never again. Second to Girling is Gabriel, they make decent shocks for the money. The rest are a total waste of money. I'm sure there's other opinions and other shocks, but the bottom line in my experience, buy the cheapest. 2,500 miles and they're gone, no matter what you paid for them.
mikespain
Before you change the shocks check the subframe mounting bush just in front of the wheel they have a tendency to break,while bouncing the car makes a clunking noise
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
F Refilling and servicing Armstrong Lever Arm rear shocks Austin Healey 4
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
T TR2/3/3A TR-3a Rear Shocks Triumph 1
T TR2/3/3A Rear shocks and rattle Triumph 5
T BSW Filler Plug Armstrong Rear Shocks? Spridgets 2
mgedit TR2/3/3A Rear Shocks Loose Triumph 16
KVH TR4/4A Loose Rear Shocks on my IRS Triumph 7
T TR6 TR6 aftermarket rear shocks Triumph 35
Keith_M Rear Shocks Spridgets 5
Boggsy64 MGB Rear Rebound straps and shocks MG 5
1 TR6 oil for rear shocks Triumph 5
S Clunking from rear shocks ...? Austin Healey 15
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Gerard Spax rear shocks on Bugeye Spridgets 12
KVH Replacing Rear Lever Shocks with Tube Shocks Triumph 24
D MK2 rear shocks Jaguar 3
K TR2/3/3A TR3A: Refilling rear shocks? Triumph 4
S 91 XJ6 rear shocks needed Jaguar 3
I TR6 What type of oil for TR6 rear shocks? Triumph 2
v8mgbal Rear shocks Spridgets 8
Tronch Rear shocks and anti roll bar Austin Healey 4
AUSMHLY After market rear tube shocks Austin Healey 28
davester MGB MGB rear tube shocks...which ones? MG 18
C Rear Shocks Triumph 17
tahoe healey rear shocks again Austin Healey 16
R Koni Rear shocks, setting? Triumph 2
mgbmedic MGB rear tube shocks for MGB MG 20
R TR6 TR6 rear ride height with tube shocks Triumph 5
MadRiver Rear Shocks Triumph 19
P 2 questions Alternator conversion and rear shocks Triumph 4
Wana Installing new rear shocks Austin Healey 8
T tr4-rear tube shocks Racing 2
George Zeck 1/4 ellipticals & Rear Shocks .... Spridgets 11
T Filling rear Bugeye shocks - any tips? Spridgets 7
bluemiata90 Leaking rear shocks Triumph 11
jaybird Rear shocks MG 21
R TR6 '74 TR6 Rear Shocks Triumph 18
Hegg Elan +2 rear shocks Lotus 4
C MGB MGB Rear Shocks MG 5
S Rear Shocks Austin Healey 2
Basil Rear Shocks installed Jaguar 9
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
