Quick Coil Question.
PlaidMan
I have a Bosch Coil on a 58 TR3A with positive ground. It has + and - markings, which side should be wired to the distributor and which side to vehicle power and if I switch the car to negative ground, should the connections be reversed?
P
PlaidMan
Andrew, the car was hooked up for neg. ground, don't know if that is part of my problem I'm having but will check it out shortly. Thanks, Charlie
TR3driver
Great Pumpkin - R.I.P
The car will still run with the coil connected backwards. Might not run quite as well, but usually you can only tell the difference in how easily it starts or how long you need to keep the choke out to keep it running smooth.
tosoutherncars Quick question - 1500 wiring for coil Spridgets 7
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
T MGB Quick question about something that don't really matter just want to know. MG 9
dougie A Quick Trip Around Oulton Park.... Austin Healey 3
S Wedge tr7/8 quick release steering wheel Triumph 0
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Gerard Datsun 5 speed Quick shift/short shift prototype Spridgets 41
Got_All_4 TR2/3/3A Quick Overdrive Wiring Question Triumph 6
P TR6 Quick starting Triumph 2
S MGB 1980 MGB quick question MG 2
2billydavies TR2/3/3A Just a quick thanks to everyone who helped with my questions Triumph 7
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
J General Tech Quick Dist question. TR3/4 vs Heralod Triumph 12
mgedit TR2/3/3A Quick Question on Thermostat Triumph 14
judow Can't post except in quick reply and other issues FORUM Navigation Questions 0
Willie_P TR4/4A Quick HELP - TR4 fender beading.... Triumph 3
H quick insulation paint color quesrion Austin Healey 7
bthompson A quick 1500 fix for when you go for reverse and rip off your shift lever! Spridgets 4
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
S TR6 Quick TR6 alternator question Triumph 6
S TR6 Quick TR6 gear reduction starter wiring help Triumph 10
M Quick tachometer wiring question on a '65 Spridgets 10
Jim_Gruber Quick Engine Install for Bugsy II Spridgets 22
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
Willie_P Quick question: rear diff TR 3/4 Triumph 6
Willie_P Help: quick hub torque questions Triumph 3
RAC68 A Quick Question [Clutch Master Seals] Austin Healey 2
aeronca65t MGB Quick MGB motor swap MG 3
MCNX_BFF Quick catch-up and trailer question Triumph 8
RJS Radiator Fan Bolts - need quick help Triumph 4
skelly Quick question from a newbie Spridgets 10
B Smelling like fuel and oil after a quick drive? Austin Healey 29
PatGalvin Captive nuts?? quick question Triumph 7
abarth69 quick help needed Spridgets 3
JPSmit Quick Spark plug question Spridgets 10
Coyote1 Need a quick measurement Triumph 7
T TR4/4A Two quick OD TR4a wiring questions Triumph 7
regularman Quick, right now go to ESPN Spridgets 2
glemon Quick Easy Removeable Cupholder Triumph 4
Randy Forbes Quick's trip to the Morgan Motor Co., LTD... Austin Healey 4
J Details, Details. Quick questions. Spridgets 11
PATR8 a quick look at the Pittsburgh Craigslist Triumph 1
drooartz MGB That was quick: MGB heading to my garage MG 24
Sarastro Quick dumb transmission question Spridgets 9
S A quick introduction Spridgets 21
T Quick fuel pump question - mounting angle MG 3
S Quick Release Steering wheel hub Triumph 1
T TR4/4A TR4a retrofitting of roll bar - quick question Triumph 1
M Spitfire Quick fix for spitfire sag Triumph 7
bigjones HS4 - quick question MG 6
