Radiator Fan Bolts - need quick help
RJS
Hi All,
I'm in the middle of remounting my radiator fan with new hardware. Quick question, how tight do I torque the mounting bolts?
My question is b/c I know the rubber bushings in there are supposed to provide some vibration damping to the hub. And, if I crank it down too tight, do I defeat the purpose of the rubber bushings?
I can tighten them to just snug. Or, crank them down fairly tight. Either way, the tab washer will lock the bolts in place once I bend the tabs up against the bolt heads
Thanks for a speedy reply
Bob
TR3driver
Great Pumpkin - R.I.P
There should be steel sleeves inside the rubber bushings; the bolts pull down against the sleeves. At least that is the arrangement on the earlier TRs, I assume it is the same for a 4A. 8-10 ftlb should do.
RJS
RJS
Thanks Randall,
Yep, got the steel sleeves in there. I just checked my Bentley manual which advises 16-18 ft/lbs. I have a torque wrench but, I think it is a large 1/2" drive unit. So, it may not be sensitive enough.
Anyway, 16-18 sounds moderately tight. More than "just snug" but less than "cranking them down".
Thanks for jumping right on this.
Bob
RJS
RJS
Yep, got the whole fan mounting kit from TRF. Comes with everything. Part no. RFK538.
Cheers
Bob
G TR4/4A Radiator Fan and plates spanning bolts Triumph 6
S Installing a Radiator Fan Austin Healey 9
RJS TR4/4A Radiator Fan Shround Triumph 3
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
J BJ8 Radiator Fan Austin Healey 12
K TR2/3/3A Volvo 122 radiator fan on a TR3? Triumph 3
FlyingCat Spitfire Electric Radiator Fan Triumph 10
FlyingCat Spitfire Radiator and fan Triumph 5
JFS TR2/3/3A Radiator fan temp probe Triumph 3
E TR4/4A TR4 Radiator position with Macy's garage Fan Triumph 6
Superwrench Radiator Fan Guard BJ 8 Austin Healey 4
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
rjc157 Electric radiator fan Austin Healey 11
DanLewis How far is your mechanical fan from the rear of your radiator? Spridgets 39
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
DanLewis Distance between mechanical fan and radiator core Spridgets 17
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
johnrip Wedge tr7 radiator fan Triumph 1
RJS Balancing a radiator fan[?] Triumph 18
AUSMHLY Check out this radiator fan Austin Healey 6
eschneider custom electric radiator fan switch Lotus 3
Mark Jones Electric radiator fan replacement options Triumph 3
QuickSilver Radiator Cooling Fan MG 10
G Radiator - Fan - Coolant ? Triumph 4
QuickSilver Question On Radiator Cooling Fan MG 5
T TR2/3/3A Tr3 Radiator fan loose Triumph 33
pjsmetana Spitfire Spitfire Radiator Fan Triumph 3
K radiator fan shroud Triumph 21
Mark Jones Radiator fan motor - rebuild? Triumph 4
6 Moss Recall: Tropical Radiator Fan Austin Healey 46
kyreb1862 T-Series Radiator Cooling Fan Switch MG 6
P Radiator Fan Shroud [aka finger protector] Austin Healey 1
G Ron Davis aluminum radiator and Spal fan pics..... Triumph 9
T Wedge TR8 radiator fan recommendations Triumph 0
LastDeadLast Custom radiator and electric fan stuff. Triumph 3
S Radiator Fan Clearance Austin Healey 11
Michael Oritt Wizard Radiator Austin Healey 7
5 MGA Radiator MG 2
W TR2/3/3A 1960 TR3A Radiator replacement recommendations Triumph 11
S Install drain cock in radiator. MG 2
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
S TR2/3/3A radiator on Ebay Triumph 4
T For Sale TR3A Original Radiator Triumph Classifieds 3
R For Sale TR6 RADIATOR ORIGINAL STANPART Triumph Classifieds 0
T Radiator Hose Size Austin Healey 2
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
Simmo MGA Aluminium Radiator AUSTRALIA MG 17
MadRiver TR5/TR250 TR250 Radiator Cap Recommendations Triumph 1
nevets Radiator Service Austin Healey 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
