Jayrz
Ok so I am re-assembling my front suspension with poly bushings on my 64 B.
I know the A-arms are supposed to pivot on te shaft so,,,
Does this mean I only apply lube to the inside of the bushings and on the shaft?
No lub should go on the outside of the bushing to lube inside the A-arm correct?
Other problem is with the poly bushings in I cannot get the castle nut on low enough to get the split pin in.
Any advice?
Jay
Any advice?
Jay
