Recommendation/source for poly bushings
tdskip
In research mode here still, but wanted to see what vendor you all recommend for poly bushings. I've decided against rubber for a number of reason (which I know some would disagree with).
I'm not looking to build a race car and would like to be somewhere in between stock rubber and delrin in firmness.
Any ideas/experience to share?
Thanks!
leecreek
Just did my BugEye's top trunion bushings. Switched from nylatron to the poly from Moss. I don't have many miles on it since but it does seem to be fine and a little more compliant. The nylatron ones were 20 years old or so...not worn out but looking for something a little softer.
T TR4/4A Recommendation on top for a late TR4A Triumph 8
B Recommendation on wheels Austin Healey 19
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
G Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
Jim McCauley TR6 TR6 Radio recommendation Triumph 4
S TR2/3/3A Front coil spring recommendation? Triumph 7
JimTR4 TR4/4A Battery recommendation Triumph 11
S Grease Gun Recommendation? Spridgets 7
M General MG Shop recommendation....Baltimore - Washington corridor MG 9
M TR2/3/3A Shop recommendation---Baltimore-Washington corridor??? Triumph 4
maxwedge5281 auto transport recommendation Austin Healey 10
G General TR Machine shop recommendation around Green Bay, WI Triumph 1
Marvin Gruber BJ8 convertible top recommendation? Austin Healey 0
R Seeking Upholster Recommendation Austin Healey 4
D Recommendation for new core in original 1967 Austin Healey radiator Austin Healey 5
AHS TR4/4A Looking for piston & liner recommendation Triumph 17
C Recommendation for Healey mechanic in Naples/Ft. Myers Florida area? Austin Healey 11
S Rust treatment recommendation? Austin Healey 5
P Good fitting car cover recommendation? Austin Healey 9
DornTRoriginal TR2/3/3A TR3 Battery Recommendation Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
I Bigeye fuel filter and placement recommendation? Spridgets 8
T TR2/3/3A Camshaft Recommendation Triumph 13
tmcarthur Tool Recommendation Spridgets 7
PAUL161 T-Series New Firestone Tires Recommendation MG 2
B Recommendation for Healey Blue and Old English White Paint Austin Healey 15
bighealeysource recommendation on replacing rear brake cylinders Austin Healey 13
B Replacement Interior Recommendation Austin Healey 11
J Lotus europa 5 speed need recommendation for transmition work [Flordia] Lotus 3
J Restorer recommendation Austin Healey 33
L TR4/4A Surrey Top repair recommendation Triumph 2
P Overheating after shut down & recommendation on thermostat Austin Healey 3
M Pebble Beach/ Monterey Good Accommodations Recommendation Austin Healey 13
S Texas restoration recommendation? Austin Healey 2
B Interior Recommendation Austin Healey 8
H Carb rebuilder recommendation? Triumph 5
Patrick67BJ8 Oil Pump Recommendation[s] for BJ8 Austin Healey 12
L PPI recommendation, Jacksonville? Austin Healey 2
B Battery recommendation besides Optima Austin Healey 17
toysrrus TR2/3/3A Spark Plug Recommendation for a TR3: Triumph 9
boeingpilot Shop recommendation Ft. Worth, TX Triumph 11
E TR6 TR-6 Tune Up Shop Recommendation Triumph 7
D Steering Wheel Recommendation MG 4
G SU book recommendation needed Spridgets 7
Michael Oritt Need muffler recommendation Austin Healey 16
This14u Spitfire 1500 Spitfire Header Recommendation Triumph 0
T Thermostat ugliness & temp range recommendation Spridgets 13
T Sway bar recommendation for a Bugeye Spridgets 21
King_of_England Race clutch kit recommendation??? Racing 5
T Recommendation on new harness for Bugeye? Spridgets 10
