TR6 Oil sending switch
davjac889
Hello all,
Anybody know the diameter of the oil sending
switch?
I can't get the original operational and I was thinking
of ordering one from JEGS.
They offer 1/8" and 3/8"
Thanks,
Bill '73 TR6
TR3driver
Great Pumpkin - R.I.P
The threads are 1/8" NPT.
DNK
Should be able to get one from your local FLAPS
poolboy
Yes....Probably too late but both the single terminal and the triple terminal have multiple applications even American cars.
Here'a NAPA part #'s for Echlin switches:
Single Terminal = OP6612
Triple Terminal = OP6610
D TR6 Oil sending light Triumph 10
Lynn Kirkpatrick Oil Pressure with the Sending Unit MG 4
I TR6 TR6 oil sending unit thread size help please? Triumph 12
Lynn Kirkpatrick Oil pressure gage or sending unit? MG 1
71tr oil pressure sending line Triumph 5
G What threads on 1500 oil sending unit? Spridgets 1
Tinkerman TR2/3/3A Oil Pressure Sending Unit TR-3A Triumph 3
PAUL161 Electric Oil Pressure Sending Unit MG 4
I thread size for oil sending unit Triumph 5
T '75 Midget Oil Pressure sending unit MG 4
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
T Spin-On Oil Filters Austin Healey 1
K TR2/3/3A Old school penetrating oil? Triumph 24
nevets Spin-On Oil Filter Adaptor Austin Healey 12
D Overdrive Stops Working After Oil Change Austin Healey 26
Celtic 77 General MG Lever shock oil refiller MG 0
I MGB Sprung an (oil) Leak! MG 2
S TR2/3/3A Aluminum oil gallery plugs Triumph 9
WHT Oil Sump Question For Dougie Austin Healey 0
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
A TR6 spin on oil filter for tr6 Triumph 4
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
LD-Ordie TR2/3/3A Canister Oil Filters Triumph 9
B Oil (or Coolant) Leak Austin Healey 10
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
kodpkd 1961 BT7 engine oil Austin Healey 31
