might as well syndrome
69tr
I pulled the head to change the gasket, might as well get the rocker shaft reconditioned.
Pulled the oil pan to look for missing split pin from the rocker shaft. Might as well check the rod bearings(as suggested). While I have the head and sump off I might as well check the rings and replace the thrust washer.
I am going to have to work on the PVC valve so I might as well install an electric fuel pump.
While I have some room I might as well order an electric fan and maybe a timing chain.
When does it end???
Mickey Richaud
I'll let you know...
TexasKnucklehead
69tr said:
When does it end???
Where it ends, or starts is a relative point of view.
DNK
I have a project that turned into a "might as well" project. When does it end? this might give you an idea. Last time it was licensed.
Brosky
Don, it looks like we have the beginning of a beautiful thread coming up.....
BRSLimited
This is not the end, this is not the beginning of the end, this is the end of the beginning.
My spitfire was supposed to be a simple clean it up and have fun with it last spring. Might as well take care of the rust on the rockers, might as well paint it, might as well put a new interior in it, might as well rebuild the engine, you know I really should do something with that dash, etc. I'll let you know when I get the rust done and maybe even get it in primer so it's at least one color again. I just ran across pictures of it I took when I first bought it, it's been so long I forgot what it looks like all assembled.
John_Mc
I think the "might as well" syndrome is part of the appeal of owning an LBC! Plus, when it ends (if it ever does), you have to get an additional LBC so it can begin again!
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
Steve This might go for silly money... Rover / Land Rover 1
waltesefalcon It might be sacrilege ... Other British Cars 4
RickB Anyone doing a steering wheel swap - a little loctite might be a good idea Spridgets 2
D Might be returning to Spridgets... Spridgets 5
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
H Think This Might be Part of the Problem? Austin Healey 3
JodyFKerr Wedge I might have let the smoke out [TR8] Triumph 25
Randy Forbes It might be a slug, but it sure is pretty... Austin Healey 28
DNK Might be worth a spare one. Triumph 7
JPSmit You all might be interested MG 0
G You might think I'm nuts, but I'd rather drive... Spridgets 14
D This just might get me to buy a Spridget...... Spridgets 12
C This might be a dumb question but.... Spridgets 15
Thor Any idea what this sound might be from motot Spridgets 9
RickB Bugeye might be available - value question Spridgets 8
YankeeTR You guys might enjoy this... MG 16
prb51 You might be a car nut if.... Triumph 39
F What a Healey might be Austin Healey 27
jlaird Thought you might like to see what I Spridgets 29
jaegzie What might be a desirable serial number be on a BE Spridgets 13
T Today might be the demise of the Crypt Car Triumph 19
T I might buy another Triumph! Triumph 14
bluemiata90 I MIGHT NEED THERAPY Triumph 13
jlaird Thought you all might like these. Spridgets 24
Trevor Jessie Might be a little quiet here for a few days Spridgets 24
regularman I believe a blind man, might be able to see my... Spridgets 14
G Spitfire 1971-80 Spitfire owner's might be interested. Triumph 1
bravenrace Might be a World Record - Where's Guiness? TVR 3
kyreb1862 Might As Well's MG 2
jlaird YOU MIGHT BE A SPRITE DRIVER IF. Spridgets 26
T Wedge Nice TR8 at Cars & Coffee - might be for sale Triumph 0
19_again Head gasket--might as well? MG 7
jlaird Thought you all might Spridgets 1
gsalt57tr3 looks like, smells like a scam, might be a scam Triumph 7
TR4 Might be nice ....... Triumph 5
jlaird Thought you might like these Spridgets 3
jlaird Thought you might Spridgets 10
Steve Might do somebody some good.... Triumph 2
J thought you guys might like this TVR 2
6 Thought some of you might like to see my Sprite Spridgets 40
regularman Important question [I might have just screwed up] Spridgets 8
T TR6 "Might as well" if you need to pull the TR6 dash Triumph 6
budk1953 You might want one British Motor Corp 9
ahpook This might be a sin, but Spridgets 7
YankeeTR You might enjoy some of these pictures... Triumph 8
