I pulled the head to change the gasket, might as well get the rocker shaft reconditioned.
Pulled the oil pan to look for missing split pin from the rocker shaft. Might as well check the rod bearings(as suggested). While I have the head and sump off I might as well check the rings and replace the thrust washer.
I am going to have to work on the PVC valve so I might as well install an electric fuel pump.
While I have some room I might as well order an electric fan and maybe a timing chain.
When does it end???
When does it end???
