TR6 "Might as well" if you need to pull the TR6 dash
tdskip
My turn signal wires are gone, and I've had no luck trying to remove the column harness cover (#123 on the below)
So I'm planning on pulling the dash panel off so I can get better access.
Any might as well items while I'm under there?
T
Tinster
Re: "Might as well" if you need to pull the TR6 da
Td-
You should not have to remove the dash to install
new turn signal wires. The harness cover has a
bit of wiggle to it if it is not filled with old wires.
Make sure all the old TS wires are out. You access
the other end of the harness cover from driver's footwell.
Yes, an awkward position but brief time spent there.
It is a tight fit but the new wires will fit in the opening
you have without taking out the dash. I did mine with
oversized wires and I'm really lame when it comes to such
things. You can do this thing. Here's how it should look.
Turns, driving lights and horn wires all go thru the cover.
PS: My advice on your dash. Unless you have a problem of some kind; leave the dash alone. A real pandora's box once you remove it. Dale
T
tdskip
Good point Dale!
I didn't think to pull the old wires first. Seems kind of obvious now that you mention in!
DNK
Dale- Are you missing the part #123 in the above drawing??
T
Tinster
No, part 123 in directly at the arrowhead.
but thanks,
d
DNK
Now I see it, on the later cars there was a part above that I think.A part for the Ign. switch or something. It has been a while.
T
tdskip
Looking at this more closely, my part #123 has a lip that fits into #90 so you can't just pull it down. There is a metal tab that prevents it moving so as to open up a bigger gap to thread the wires through.
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
bluemiata90 I MIGHT NEED THERAPY Triumph 12
JPSmit Not quite an LBC - but the size might be close :) Restoration & Tools 3
M Wanted I tried to post this earlier and it didn't seem to work so this might soon appear as Austin Healey Classifieds 6
davester Help me make some engine teardown/evaluation/might-as-well decisions please. Spridgets 6
Steve This might go for silly money... Rover / Land Rover 1
waltesefalcon It might be sacrilege ... Other British Cars 4
RickB Anyone doing a steering wheel swap - a little loctite might be a good idea Spridgets 2
D Might be returning to Spridgets... Spridgets 5
Lbp TR2/3/3A What Might Cause The Entire Electrical System on my TR3A to Die? Triumph 19
H Think This Might be Part of the Problem? Austin Healey 3
JodyFKerr Wedge I might have let the smoke out [TR8] Triumph 25
Randy Forbes It might be a slug, but it sure is pretty... Austin Healey 28
6 might as well syndrome Triumph 11
DNK Might be worth a spare one. Triumph 7
JPSmit You all might be interested MG 0
G You might think I'm nuts, but I'd rather drive... Spridgets 14
D This just might get me to buy a Spridget...... Spridgets 12
C This might be a dumb question but.... Spridgets 15
Thor Any idea what this sound might be from motot Spridgets 9
RickB Bugeye might be available - value question Spridgets 8
YankeeTR You guys might enjoy this... MG 16
P You might be a car nut if.... Triumph 39
F What a Healey might be Austin Healey 27
jlaird Thought you might like to see what I Spridgets 29
jaegzie What might be a desirable serial number be on a BE Spridgets 13
T Today might be the demise of the Crypt Car Triumph 19
T I might buy another Triumph! Triumph 14
jlaird Thought you all might like these. Spridgets 24
Trevor Jessie Might be a little quiet here for a few days Spridgets 24
regularman I believe a blind man, might be able to see my... Spridgets 14
G Spitfire 1971-80 Spitfire owner's might be interested. Triumph 1
bravenrace Might be a World Record - Where's Guiness? TVR 3
kyreb1862 Might As Well's MG 2
jlaird YOU MIGHT BE A SPRITE DRIVER IF. Spridgets 26
T Wedge Nice TR8 at Cars & Coffee - might be for sale Triumph 0
19_again Head gasket--might as well? MG 7
jlaird Thought you all might Spridgets 1
gsalt57tr3 looks like, smells like a scam, might be a scam Triumph 7
TR4 Might be nice ....... Triumph 5
jlaird Thought you might like these Spridgets 3
jlaird Thought you might Spridgets 10
Steve Might do somebody some good.... Triumph 2
J thought you guys might like this TVR 2
6 Thought some of you might like to see my Sprite Spridgets 40
regularman Important question [I might have just screwed up] Spridgets 8
budk1953 You might want one British Motor Corp 9
ahpook This might be a sin, but Spridgets 7
YankeeTR You might enjoy some of these pictures... Triumph 8
jlaird Thought youall might like to be the first to know Spridgets 11
